Push the slider to the "V" with the solid and dashed lines above it. This is DC voltage. Turn the rotating selector knob to "2". Use this meter setting for both bias and DC offset readings.
For bias you want 10mV which, on the meter, should look like 0.010 or similar (not sure how many digits will show on your meter, might read .01 or 0.01)
For DC offset the goal is as close to 0.00 as possible. You may or may not be able to get exactly 0mV. If you are able to get DC offset at 10mV or less that would be excellent. 20mV or less would be very good. Let us know what you are able to do with the DC offset.
As far as those fuse resistors you definitely want the amp OFF, and UNPLUGGED when reading those. In that case you are not measuring circuit voltages as in bias of DC offset. With the fuse resistors you are measuring the actual value of the resistors in ohms. Those fuse resistors tend to drift very high so you may need to try different settings on your meter to find one that will give you a reading.
