AU-D907 LIMITED vs 919
Can some of the electrolytics on the amp board be replaced with non-polar caps?
If by 'non-polar' you mean Film Capacitors, the answer is yes. I am speaking only of C07,C19,C33 and C08,C14,C34. And if you don't want to do them all, C33 & C34 changed to PET or Polypropylene type will almost certainly make the biggest difference.
If by 'non-polar' you mean Film Capacitors, the answer is yes. I am speaking only of C07,C19,C33 and C08,C14,C34. And if you don't want to do them all, C33 & C34 changed to Polypropylene type will almost certainly make the biggest difference.
Thank you sir. And can you tell me exactly the series of wima?
If I were you I would not change that since what you have is perfectly ok. If you want to change them, then skip electrolytic capacitors for C33 and 34 which are only 1uF. If you want to use better capacitors there, then follow what Leestereo suggests which is use film capacitors like wima or kemet or panasonic with 5mm lead spacing. You could go with PET because the polypropylene film capacitors are more likely be too big to fit there.
Just be careful not to lift the pads on the PCB.
All those caps that I put in there still look new.
If I were to change those caps then how can I be sure how much difference in sound is caused by the driver transistors change? It may be wise to just put those transistors in and leave the caps in there. I for one want to know if the transistors make a difference.
What do you guys think?
Only change one thing at a time is my philosophy.
But then again, you might not want to spend that much time, fitting one thing, trying it, pulling apart and swapping more things.......I feel the combination of the two may give you some nice results, enjoy it, and don't worry about what might be the contributing factors.
I noticed that C05 & 06 are those clear plastic caps (different looking) are 100pf. At least that's what the service manual say they are. I am thinking about replacing them with 100pf silver mica.
What kind of caps are these strange looking things?
