To avoid all these '200 Capacitor Questions or Bust' - why don't you follow Leestereo's choices to the letter? - he gives the value/voltage and exact type (often giving the 'why' as well), of each component in his excellently documented restores.
I don't think arranged like the filtered frequencies go anywhere, what I think does happen is that they make the positive and negative rails look equal noise-wise, thus cancelling it out. IIRC Sansui design documents mention prevention/elimination of undesirable earth currents, this may be one of those tweaks.This is something I still am not sure about, there function. On the schematic of the AU-819 they are placed between positive and negative rail. So if they filter, where to does it go? ( the filtered frequencies)
That's because people unfamiliar with electronics, and audio amplifier circuitry in particular shouldn't do it - EVER. Unless it has been recommended by one of the more knowledgeable members who have this skill.The reason for all the questions was because I am not the only one to be concerned about changing the values of caps from what the factory put in there.
So you are going to 'downgrade' those capacitors then?I am going to replace them with Murata COG caps.
I was worried about that too. Of course polystyrene film capacitors also can go bad, and they will, as the story of Dorian ( and bumpalump would mention this to, although he would not change them out wholesale) is evidence of.So you are going to 'downgrade' those capacitors then?
Wouldn't it be better to find out if any of the Noble capacitors are faulty first?
That's because we KNOW the Black Flags are bad actors, and because of their construction (tiny, radial, stable dielecric), the C0G ceramics are the best replacements available under the circumstances.On the other hand, we change the "black flags" for C0G ceremics !
We will see. Thanks Dorion!Best not waste your time with the driver transistors then.![]()
Add to that and as I’m known as an “Indian with a screwdriver “ I have found out that using aIf you can make sure you won't heat them to much ( using a heatsink on the leads)
Daaaaa what does that mean??Add to that and as I’m known as an “Indian with a screwdriver “ I have found out that using a
heatsink and wrapping around the lead of the polystyrene a cotton deep in alcohol , no heat is “climbing “ to the body of the capacitor !
PS: @ghamilton i feel you , I have already Google more than ones “GaAs” …. hard to get![]()
About the cotton and the alcohol part ?Daaaaa what does that mean??
I dont think I have a way of testing pf values. I am just replacing them so I don't have to worry about it.About the cotton and the alcohol part ?
I know it’s a little unorthodox method but it keeps the capacitor “dead cold “ , I suggest if you go through the replacement or measuring the actual cap out of the circuit , apply the method .
About the other part with Dorian’s approach to restoration , I suppose I’m stunned and exited as you and I’m Googling “staff” he said or propose to see what I can learn and why not, purchase and replace components , to “ better” my already “best” sounding Sansui’s
Hope I haven’t been miss understood ? Or ?
Defiantly!!!I'll bet it's the transistors!
