AU-X1
All you may seek to about know about those is here...
http://audiokarma.org/forums/index.php?threads/g9000.693759/page-4
And here...
http://audiokarma.org/forums/index....apan-to-export-model-plus-restoration.477461/
FYI+: Amp8 never replaces those. Kale always does.
Take the easier path or open up a small can of carcinogenic dioxins.
I'm guessing you're snapping on the rubber gloves as I write.
FYI++: E means .... (drum roll) earth.
And here...
They're measuring out around 1098uf on my dmm
The earth / ground / common is both.
The earth / ground / common is where positive and negative meet.
As it shows in the picture
in the previous posting.
(The illustration below was provided by Kale.)
index.php
index.php
I see what's what now.Things sink in slowly when I'm working nights and trying to see everything from this stupid phone:)
Dang dude.
Hope this is actually relaxing for you.
I think I understand your situation better.
I hope this is a relaxing thing for you. A stress reliever.
Dang dude.
Ya I'm working 12 hour night shifts this week 6:30pm to 6:30am and I haven't been sleeping very good during the day when my dog barks at every car that drives by
Ok I just got home from work and re measured these dual caps the right way and this is what I got20160708_072838.jpg 20160708_072731.jpg2046uf and 2130uf on the other one.Should I leave them like this or rebuild them like Kale did??
It's up to you - those look alright from what we can see, and would almost certainly be OK for a few more years.
If you can afford the parts, and the time, and are confident that you understand exactly how Kale re-stuffed his, then it might be a good idea to do them.
Yes I understand how Kale did it now that I took a good look at his illustration but I'm thinking I'll try to get it up and running with these ones and then later down the road re do them and the twelve 10000uf 80v caps at the same time..
I mean eight big caps..I can't seem to count very well with sleep deprivation either:)
1+ That plan too. Those are looking real good.
Fabricating new duals is a delicate procedure. You have to minimise damage to the housing while yanking out the highly toxic innards.
Amp8, who has restored more X1s and X11s than anyone, always leave those in place. So consider leaving the duals in place a low risk choice.
Yep - sounds like a plan.
Slept like a rock today when I got up I decided to check the other two dual caps from the parts unit and discovered that the two square transformers (one from each unit)are different. This one from the parts unit is pretty rusty and this is the only writing on it that I can see20160626_125235.jpg
Slept like a rock today when I got up I decided to check the other two dual caps from the parts unit and discovered that the two square transformers (one from each unit)are different. This one from the parts unit is pretty rusty and this is the only writing on it that I can seeView attachment 758713
This one from the 100v unit is clearly different so I'm not sure if it will work with my idea of changing the 100v unit into an 20160708_153453.jpg 20160708_153529.jpg adjustable voltage unit and I'm not sure if the rusty one works yet.
