AU-X1
One (the left one?) is for Japan only, the other would be for the multi voltage one.
So reinstall the one that was matched to your multi-voltage toroid.
So reistall the one that was matched to your multi-voltage toroid.
That's the plan but looks to be in pretty bad shape hopefully it works
Any chance for a pic of the adjustable / multivoltage one?
That would be very helpful information for all.
Perhaps a pic of the other side of this?
index.php
F-2778 is going back in after a recap new trimmers and changed some resistors everything else is original 20160709_195350.jpg 20160709_195406.jpg
Sorry I already sanded and painted that one a few weeks ago but here is a pic still installed on the unit and as you can see there is nothing there but rustView attachment 758747
Good news both of those rusty old transformer's test good I'm about ready to put everything back together and see if I can make it tick..
In case y'all were a wonderin yes I put a thin layer of new heat sink compound between these transistors and the anodized heat sink no mica insulators in between..20160709_211849.jpg
Looks good!
That thermal paste seems fine.
Glad that transformer tested out good.
Seems you are beginning to see some light at the end of the tunnel.
Looks good!
Ya I seem to be muddling my way through things...Don't know why I've been racking my brain on what wire means what on those transformers until Kale schooled me on the importance of looking the schematic over and then the light of day settled in on my tired Ole brain:)
Looks good!
The old rusty toroidal transformer is shorted I found..guess i'll give this x1 a burial at sea...
Crap.:(
You can get a new non-original toroidal to replace it. Seen videos on YouTube of some who've gone that route. (That would certainly be a learning experience worthy of sharing on AK.)
If not that, there are still a lot of good salvageable parts like the chassis and the PC boards. I bet a fellow AKer or two would be glad to have it.
The copper in there has value.
But then again...nothing like a clean break. Eh.
Crap.:(
I still have the the 100v one and I just bought a bunch of g9000 parts including the toroidal transformer they should be arriving this week and I was looking at mine last night all of the wires appear to be the same, they're both 160 watt per channel units,they look to be about the same size,hmm...
I always assumed that the g9000 and the X1 used the same toroidal.
Kale has done work on both models. He can confirm if they directly swap out.
BTW: Is the g9000 toroidal you are getting voltage adjustable?
If I remember correctly you proved that the single voltage version has a couple fewer wires
than the adjustable toroidal.
If it is adjustable, you should be back on track.
Yes it is adjustable
