AU-X1
"Back to the drawing board" meaning just retesting the transformer?
Or is it a bit more serious?
Like abandoning the first project X1 and moving on to the 100v version?
No that transformer is good I need to put it back in and figure out where the short circuit is.I think it's on f-2781 somewhere so I have a few ideas for trouble shooting I'm gonna try
Are the phono mother board cards all mounted properly?
If yes.
Then might one of the traces on the back of the 2770 equalizer card be making contact with the ground collector tab?
If yes.
l see what you're saying about the ground tab and I'll put some type of insulator between there but I think I'm gonna go thru things again and put new transistors and diodes in like John did.You wouldn't happen to have a diode and transistor replacement list handy would ya?
Sorry, but the list I created was deemed unsafe by EchoWars.
So I dare not share it any longer.
BUT what I actually ended up doing was leave in most of the diodes. With painstaking testing I found that they were all good anyway.
I only swapped out all the Zener diodes, and two old germanium diodes for new ones on the driver board, and traded all VD1212 for two 1N4148's in series, and all MV 103 with three 1N4148's in series.
Tried and tested upgrades only
The reason I suspect F-2781 is because when I unplugged the wire plugs that the arrows are pointing at the dbt still glowed bright and when I put the plugs back in and unplugged the red wire (circled)the dbt went dim and the soft start relay clicked and lights on the front panel came on.And that was also the reason I suspected that transformer. 20160714_205533.jpg
The reason I suspect F-2781 is because when I unplugged the wire plugs that the arrows are pointing at the dbt still glowed bright and when I put the plugs back in and unplugged the red wire (circled)the dbt went dim and the soft start relay clicked and lights on the front panel came on.And that was also the reason I suspected that transformer. View attachment 761524
That pic is of the old board before I started
I'm at least gonna replace all of the 2sa992,2sc945 and 2sc1845's and the zener's and vd1212 and 1s2473's also the mv12 and mv103 with in series 1n4148s
Double check the back of your 2781 and make certain that nothing from the back of the board touches the chassis.
I left an untrimmed captor lead the resulted in similar issues during my first power up.
I pushed the work and paid for my impatience by missing the obvious.
20160714_224346.jpg These outputs were in the rusty old 1978 model and I'm wondering if any of you guru's can identify them.
I sure hope it's not one of these thingsView attachment 761504
That is a bridge rectifier, they don't usually blow, there is a direct replacement but you have to swap all 4 leads so the pin-out matches. You should 'Google' how to test them - it might come in handy - but it is best to remove them to test, otherwise you will get confusing readings.
That connector you pulled off is one of the feeds to the power amplifiers if I am not mistaken - the kind of thing that would cause an issue would be a short on an OP transistor or on one or more of the main capacitors? or maybe a trapped wire somewhere?
So, it is fairly unlikely that your issue was caused by something on the F-2781 board itself.
That connector you pulled off is one of the feeds to the power amplifiers if I am not mistaken - the kind of thing that would cause an issue would be a short on an OP transistor or on one or more of the main capacitors.
Yes I also suspected the main caps but my dmm measures OL so I'm not sure if they're bad or my dmm can't handle that high of capacity
