View attachment 761541 These outputs were in the rusty old 1978 model and I'm wondering if any of you guru's can identify them.
Almost impossible to identify without any information - could get an idea with a curve tracer but that's all 'an idea'.
Yes I also suspected the main caps but my dmm measures OL so I'm not sure if they're bad or my dmm can't handle that high of capacity
I removed one from the rusty 78 model and it measures OL but I also have some brand new ones that also measure OLIt would read like that if for example one of the main capacitors was reversed? - which would also give you a bright Dim Bulb indication, any chances of that? - have you done any re-wiring or removal of the main capacitors?
Not the case bulb stayed brightI was thinking if the OPs were bad and I disconnected the plugs to them the dbt should have Sucked the life out of that bulb
That is a bridge rectifier, they don't usually blow, there is a direct replacement but you have to swap all 4 leads so the pin-out matches. You should 'Google' how to test them - it might come in handy - but it is best to remove them to test, otherwise you will get confusing readings.
That connector you pulled off is one of the feeds to the power amplifiers if I am not mistaken - the kind of thing that would cause an issue would be a short on an OP transistor or on one or more of the main capacitors? or maybe a trapped wire somewhere?
So, it is fairly unlikely that your issue was caused by something on the F-2781 board itself.
We'll get to the bottom of it eventually right now I just ordered replacement diodes and transistors and I'm gonna replace those before I re connect F-2781Yes all capacitors will measure OL on a multimeter, no matter which way round you test them, after a brief period to charge them up. The DBT indication will tell you if one or more of the main capacitors is bad or possibly reversed - showing 'bright' = too much current.
Not quite sure what you mean here, a short on an OP transistor, or a bad or reversed main capacitor will show BRIGHT on the DBT. In your example you narrowed down the fault by disconnecting that feed to the power amp (good!). So now you should be looking for why you got a Bright bulb with that connector connected - you should check out my suggestions as being the most likely causes, when you have eliminated them, and corrected the fault, we/you can think about moving forward.![]()
Also I was gonna say that the red lead circled in the pic is the power in lead for the toroidal transformer it is in line with a fuse that connects to the 120v power cordWe'll get to the bottom of it eventually right now I just ordered replacement diodes and transistors and I'm gonna replace those before I re connect F-2781
Here's a better look at it.
Yes they test goodWilly, you do have an Atlas transistor tester yes?
Have you used it on those mystery OP transistors yet?
Yes they test good
Yes red from toroidal transformer go's to 17 thru fuse f603 then thru jp02 to red 18 and white 19 which comes from power cordYes, I am sorry, that red ringed lead is not the one I was thinking of. - not sure what the function of that lead is - can you advise what pin on the F-2781 that lead goes to?
Further down the picture the 'arrowed' yellow/grey and blue/red connectors are what I meant regarding OP transistor shorts and main capacitor issues. - and I am still not sure if this is actually correct.
Ron one thing is I might ask a lot of dumb questions but once I sink my teeth in to something I don't let go I'll see it through to the endAs I said previously...only the best most experienced techs can sort out an X1 at first try.
This is normal. Certainly if you use the X1 as your first restoration.
Third time is the charm!
...once I sink my teeth in to something I don't let go I'll see it through to the end![]()
That explains why everything came on when I pulled that red wire off cause there was a white wire on 18 that came from the voltage selector as well..Not using my head I just assumed that I needed both of those wires hooked up because that was how the previous owner of the export model had it wired..Live n learn..That lead goes to pin 17 on a 100V version but to pin 18 on a multi-voltage version, and is the fused line for the 100V only square transformer.
Pin 17 on F-2781 only goes to the voltage selector block on a multi-voltage version.
