I Can't believe I had it going then I thought nope not right and then tore the transformer back out and almost used it for an anchor on my boat...That explains why everything came on when I pulled that red wire off cause there was a white wire on 18 that came from the voltage selector as well..Not using my head I just assumed that I needed both of those wires hooked up because that was how the previous owner of the export model had it wired..Live n learn..
When I pulled the red lead and the 100W bulb went dim and the soft start relay clicked and all the front panel lights lit up I honestly had it in my head that the toroidal transformer was bad and the little square 100v transformer turned everything on...I Can't believe I had it going then I thought nope not right and then tore the transformer back out and almost used it for an anchor on my boat...![]()
This amp is the first two transformer amp I've delt with and as Kale mentioned I NEED to look at and Learn schematics something I myself know is challenging for me since my eye sight isn't what it used to be..When I pulled the red lead and the 100W bulb went dim and the soft start relay clicked and all the front panel lights lit up I honestly had it in my head that the toroidal transformer was bad and the little square 100v transformer turned everything on...
Not really game over John things Can be fixed with $ and this x1 Will see the Light. .Well, it was a surprise for me too, that you actually took out the toroidal transformer having had those results.
Regarding the transformer change, I believe Ron and Myself warned you about the complexities of not only the AU-X1 - but also of facing yourself with a transformer/voltage change as well...
There are no 'step-by-step-how-to's' on this, for a lot of it you are on your own... one mistake and it can be game over.
Game over to me is when the Seattle Seahawks run the opposing team into the ground which IS on the HorizonNot really game over John things Can be fixed with $ and this x1 Will see the Light. .
Sorry couldn't resist throwing that out thereGame over to me is when the Seattle Seahawks run the opposing team into the ground which IS on the Horizon![]()
There are a whole host of other parameters not the least of which is fT for the output transistors in an AU-X1, personally I would rather use MJ2119X series replacements, than those unidentified transistors.
Please forgive me John I had a little to much to drink last night.I really do appreciate all of your help on this project.Somewhat lost on me, but I get where you are coming from![]()
I have the sacrificial Mj21194g and 93g's in there right now and when I get the thing dialed in I'll put the sanken LP,LN 200's that I bought from Kale in there.I was just trying to figure out what those mystery transistors are.Also I only need 3 of the sanken 2SC2493's to make another complete set so I'll be keeping my eyes open for some of those.There are a whole host of other parameters not the least of which is fT for the output transistors in an AU-X1, personally I would rather use MJ2119X series replacements, than those unidentified transistors.
I was looking things over on board f-2781 of the parts unit in relationship with the schematic and I think the previous owner had it wired for 220v there are a few things I need to change around and It should work..No problem at all Willy, what I meant was that I have no interest in English football, let alone American.![]()
They also have jumper wires on the adjustable plug and the schematic shows noneI actually wondered about that too.
