AU-X1
15000µF x2 (per rail) is too much I think Willy - 20000µF per rail is sufficient.
Re: the picture above - how tall are the originals? - difficult for me to measure mine accurately as I never took them out.
Originals are 40mm Wide x 120mm length there are a number of 35mm wide x 80mm length of various brands available at mouser and I think they would fit inside the originals. One of them I was looking at were these nichicon's 647-LNR1K103MSE and they are screw terminals.
This is the closest shot I took basically I used wires with alligator clips on each end about six of them and made all of the necessary connections then plugged amp into dbt flipped the switch and the bulb went dim soft start relay clicked front panel lights came on so I new that my problem was one or more of the big caps on the original bank when the original caps were in the only way I could it to turn on was when I disconnected the wires to that side.20160718_212608.jpg
Those nichicon LKG's are snap in also and they're 80mm in length still kinda short.
The LKGs at my shop and the ones I see online are lug type.
Lug terminals are the same type of terminal that the original cap have.
I've not seen snap in versions of this cap myself.
Really? The LKGs at my shop and the ones I see online are lug type.
The ones at mouser are snap in but if I find the lug type I'd rather use them.Also I'm still trying to decide if I should stuff the original cans or change the whole look and use some short ones?
Also if I use the snap in type I can rest the 50mm wide cap on top of the bracket and run copper wire down through the hole that way I'd have the whole 80mm length sticking up.Just some thoughts on keeping the v8 under the hood look like John mentioned.I measured the originals and they are 120mm and 95mm sticks up from the bracket 25mm sticks below bracket.
I never considered "jacking up" the caps.
If you still used those big Nichicon Gold Tunes and jacked them up to be flush with the top of the drivers, like the originals, that would look really cool.
That's a great idea as far as looks go.
I wonder if wiring them instead of connecting the by rails would make difference?
An alternative would be elevating the mounting plate with spacers and longer chassis screws.
Doing this, You could still employ rails to create the capacitor bank, while elevating the caps to match the heights of the originals. Those capacitor banks are wired to their respective drivers anyway. This way you can preserve much of the original engineering.
Elevating the mounting plate may require adding longer wires to attach the cap bank to the driver, and grounding.
I'm not to keen on the idea of Making the through holes on the mounting bracket bigger and I was thinking if I could get the LKG'S with screw lugs you could use ceramic standoffs and still use the original rails.
Also copper is a better conductor then steel or aluminum so anytime you use copper it is better in my opinion.
It's gonna look pretty freakn cool.
You have two X1s, of course you're all about the sound.
But few amps look as impressive with the top off.
My X1 currently runs with the top off.
Just a matter of taste.
What about bumping the voltage rating up to 100v?There's quite a few 10000uf 100v caps to choose from.
