A loose demo of which rail goes with which lug would be a very appreciated addition to the X1 restoration library too.
New info.
Interesting stuff.
+1 Blazing a trail
New info.
Interesting stuff.
Yes negative side is marked with black.step by step pics when Im done.I'm still waiting for some wire though.Well...I'll be danged.
I suppose the tinning was to ward off the copper going green?
Nice shot of those rails btw.
Since you are the first one to show a filter cap replacement for the X1, could you show us (or just tell us) if the old filter caps have a mark for which lug is the negative lug?
New info.
Interesting stuff.
I use one of these things it's worth its weight in gold.I just heat it up enough to get a screw driver under the bent over lug and then straighten it up with a pair of pliers then stick the screw driver under the rail and pry up while heating and sucking the solderNice work.
That is a very clean removal of those rails.
What soldering iron do you use? Any special technique or solder tip?
Those rails shunt away a lot of heat from the soldering iron, so it can be tough to concentrate enough heat on the solder points to properly remove or add solder.
Not all of the pics were in the righti stuffed one cap today first of all with the clamp in the original position i took a measurement from the bottom of the cap to the center of the clamp then i put the clamp on upside down and used it as a guide to cut the black wrap then i opened up the can and pulled the guts out.View attachment 767383 View attachment 767382 View attachment 767377View attachment 767385 View attachment 767386 View attachment 767387 View attachment 767390 View attachment 767391 View attachment 767392 View attachment 767393
order but here is the finished cap.Yes I put silicone on the bolt heads like Kale does and I use gloves.You are going good there.
I hope the tops of those bolts are well insulated though...to minimize the the possibility of of something shorting out or arching.
Finally, please make sure you use rubber gloves when you gut those caps. The chemicals in those things are really toxic.
I never thought of it I guess I'll study up on the reason why and how to do it.Any thought to adding bypass films to those main caps?
Easily removed later after critical listening once broken in, many like this mod![]()
Are you talking about those ?There are many many posts about this simple mod, however I bookmarked this one from a few years back, thanks EW as always.
http://audiokarma.org/forums/index.php?threads/filter-caps-bypassed.336048/
Should I put new ones in there or re use those ones?they test good..
And you were suggesting adding more right?If I add more should I go bigger or smaller?The main caps are 10,000uf each and those bypass caps say 105k on them.Others may say differently however they usually never need replacing.
