a.wayne
Well-Known Member
Who knows of a vendor who does custom metal work? I'm looking to have a face plate done for the Otez, with the Audire logo etched or cut into the metal.
I see you still taking care of my amplifier .... ?
It's an early single switch. I'm not sure if Julius is still with us. At one time I had his contract information. Unfortunately I don't know where it is. If I run across it I certainly share that.Hello Corrine ,
Is yours the early single power switch model or the dual ..? Does anyone know if Julius is with us and have a contact number , it's been awhile and i have lost his info ...
Regards ..
I see you still taking care of my amplifier .... ?![]()
Does that mean you owned the very unit that has been in my system for the past several years or that you owned a similar dual breaker/ power switch Otez?I still own a single breaker unit.Does that mean you owned the very unit that has been in my system for the past several years or that you owned a similar dual breaker/ power switch Otez?
I knew that Julius had come up with a MPQ-6600 substitute a while back. But didn't know he had ever built amps with MOSFET's. Kool! I will tell you this -his class A amps after they had been powered up for about 1/2 hour were some of the best amps I have ever heard. Heavy ,gave off a lot of heat and ran the electric meter pretty well - but could grab a woofer and make it do things that lesser A/B didn't know about -while sounding so very smooth and effortless at the same time.Really don't know anything about your version of this amp - it dates from years after I quit servicing audio gear.
Sold and serviced Audire equipment for years. As far as cabling goes -these were designed in the era when almost all RCA cables were co-ax construction (center conductor + -insulating material -outer shield for - ). Spec most of us paid some attention to was low(ish) capacitance for interconnects. In the wild world of interconnects today -assumptions about interconnect construction or performance are simply foolish (has nothing to do with price). I certainly had dozens of systems that were running longer than 3 foot interconnects- 10-16 was common - .The distance from the output of the Cube to the amp should be the only issue . What is the output impedance of the Cube ? I never had a Audire amp go intermittently noisy in the way you describe -IOW -if you could turn it on for say 1/2 hour and it only became noisy some of the time - I'd suspect the KEF Cube or your preamp ??? We sold these amps for many years -with time -two service issues did occur : 1.) some units had bad power supply filter capacitors - pressure relief would bulge or rupture -Julius would provide replacements and we would replace all of them in a unit. let me be clear on this - this was not a design flaw -but a specific batch failure of a component part. LOTS of Audire's have been perkin right along for decades with their original capacitors doin the job. 2.) The MPQ-6600 would fail and become noisy-hissy typically. This looks like a IC - but isn't . It's pairs of transistors on a common substrate. The idea is that they will thermally track each other because they are contained in the same package. I do not know of a available substitute for this specific part ? Any working channel is worth something because it will have one MPQ-6600 on it -please sell these modules rather than junking them. If someone knows from personal experience of a succesfull substitute for the MPQ-6600 -please post this info.
I'd buy it as a parts donor for your fully functional unit. The only thing that is sorta unobtanium is the MPQ6600 or Julius's replacement for that part. Maybe somebody has figured that out - but I don't know who that is ? In servicing these amps for a number of years -the only consistent problems were the MPQ6600 issue (which was available from Julius at the time) and a batch of bad power supply capacitors -and Julius supplied us with those as replacements. Are you talking about a Diffet 2 preamp or a newer model power amp that came out after I was no longer servicing audio equipment ? Come to think of it - I'm not sure we ever had a defective pre-amp (and we sold lots of 'em).
