Matt -- If you (or anyone else) has such an animal (TA-800 specifying a 7247 driver tube), some good close up pics of the driver tube and tone amp tube wiring in it would be beneficial to all TA owners.
Besides the four specific problems I've already noted that invariably all the tri-pent tubes can present, when you add in the cost and availability of the 7199 along with the other generic problems that can potentially afflict all tubes in general (microphony, envelope defects, intermittents, etc.), it just makes the long term outlook for the upkeep of any set that's used as a daily driver and employing this tube problematic. If that's the case, and the 800s were ultimately modified to use the 7247, a very strong case could be made to convert the set to the latter design. This is hardly a subliminal pitch to Rob (since by all accounts it appears that the model never was updated) but rather, an honest discussion of the long term problems any set will have that uses this tube. There's also one other variable to consider as well: If a given set using this tube is paired with relatively INsensitive speakers, then problems with a specific tube example (like excessive heater cathode leakage) could be covered up to make for a workable scenario. However, if the set with the same tube is used with high sensitivity speakers, then the hum produced by such a fault would not be workable. I have three units that were originally designed with this tube (Dynaco SCA-35, ST-70, and Heath AA-30), and of those, only the AA-30 continues to use the 7199 with the thought that hopefully, the two decent spares I have of the tube will keep that unit going for the short term -- although long term, I plan to modify even it away from this tube down the road.
The design of the two TAs is remarkably similar, with in fact most of the tuner and audio circuits nearly identical between the relevant (i.e. 7199 based) 600 and 800 versions, based on available schematics. An analysis of later 600 versions to the early one shows that Fisher increased the gain in the first tone amplifier stage by ~ 180% to make up for the loss of sensitivity in the power amp section when the swap was made to the 7247 driver tube. Since the 7189 and 7591 output tubes are of a similar Gm, then it shows that a 7247 based TA-800 is at least theoretically, if not quite practically possible.
Hopefully, the new tube will arrive today so it can be checked out. Fingers crossed!
Rob -- The tint of the current LEDs not withstanding, the biggest detractor I see from the frontal appearance on your unit is in fact the dial glass itself. Specifically, the film that has accumulated on the back side of it over time. When illuminating lamps (of any color) hit it, its presence is made clear. Removing it for a proper cleaning and new gaskets is the only way to really address it. Resolving that and the LED color will knock the appearance factor of your unit waaay out of the park!
Dave
