How much available space do you have inside the unit where the transformer is mounted?
http://www.antekinc.com/details.php?p=51
Maybe not totally lost.... That whte cover with the wires going there will be the primary.... That winding you see will be the secondary. Usually you will see the thermal fuse pins in the enclosed area on that series
Just spotted that the main fuse before the transformer is rated at 630mA so a smaller torroidal would do wouldn't it? It's rated at 150W Max so that's 80VA 1.6A so would a 80VA 25Vx2 torroidal be good? Then its not stressing the fuse or doesn't this matter anyway?
...Think I might've just contradicted myself...
Just found the service manual for the amp.
It produces 21 Watts per channel
630mA fuse and max power consuption @240V is 150W
Does this give a better idea of what voltage I need going in from the secondaries?
This is a real junk amp. I suggest not spending any money to get it working. If you can get a free new transformer, then sure, but please don't buy something new. That's expensive, and this amp will never sound good.Hi and sorry yes - forgot to mention all that!
It's a Pioneer SA-420. Picked it up off someone who couldn't get it working. I've got power going in up to the transformer then nothing afterwards. The outputs on the transformer move from 0VAC to 0.01VAC when I apply power so I think its the transformer. Nothing looks blown in there either - maybe a few baked resistors but thats all.
If it helps the main electrolytics are rated 4700uF @ 35V
