------- On diode test I’m reading 1050 ohms in one direction and 800 in the other.
A diode test does not read ohms. Volts?
Weird that it was working for a while and then had a failure like that. That leads me to believe that the parts you replaced must have been installed correctly. Perhaps another issue that has been there the whole time, and is intermittent like a transistor going dolally once a certain temp is reached.
And to be clear your dimbulb signals short with the blown fuse replaced, but with the fuse removed it does not signal short? if you need to test for this fact you can do it with an even smaller bulb for a bit more safety.
