GrandDesigns
I found a Bogen AP-60 integrated amplifer that's been in storage for a while. It's filthy and I've been cleaning off the accumulated dust and grit. I have not attempted to plug it in or turn it on. I saw this post about another AP-60 and what steps to take to see if it had any life, and it mentions using a variac and deoxit. I can clean the potentiometers and switches on this one, but my main questions are more specific:
1. This looks to have tubes of: 2x 7247, 3x 12AV7/ECC83, and 4x 7355. Replacing those new could cost around $300. How likely is it the tubes are bad?
2. Should I attempt to get the tubes tested locally before powering them? There is a local electronics store near me that has a tube tester.
2. How do I remove the large capacitor cans? They're riveted in. Drill out the rivets?
3. Should I just go ahead and replace all of the components that are likely to fail? This ebay seller sells a $150 kit of capacitors, diodes, thermistor, fuse, and directions. I suspect this is $50 of parts but it would save the hasssle of sourcing everything piece by piece. I don't mind the time and expense of replacing these although I realize there's no guarantee the thing will work trouble-free even with new parts. So it's a risk.
4. Is this Bogen amplifier worth $450 in tubes, capacitors, and other components? I realize that is somewhat subjective, however Bogen is not one of the more well known tube amp brands.
I've never worked on anything of this vintage before. Wow, the assembly of things is super sketchy. No wonder circuit boards became the norm!
