Bose 601 "owner" opinions please
A dented dust cone is only a cosmetic issue, doesn't affect sound (that much, I'm sure there is SOMETHING measurably different)
I typically will insert a sewing needle into the cone and work it back out. Leaves a tiny hole, but reasserts the dome shape. Last ditch effort that works 95% of the time.
the pin hole had crossed my mind, but I wanted the opinions here. I'll go dried chewing gum, then pin hole as the last resort. I was afraid of audio quality sub standard. I get a reading of 4.5 ohms for both...do y'all think this was used in 301, 501 & 601..? It does have the housing shape of 601 series ll...both have the plastic riser mounts
tried shop vac, tried shop vac with a funnel that had closer circumference... any glue that would stick using a nail head probably wouldn't pull off w/o damage to cone. tried shipping tape... not enough sticking force. dried chewing gum was my last idea. picked up a very nice pair of 301 tweets, with one cap dented. should I not worry, send it to Bose, scrap it. I don't know if I could cut the cap away cleanly from the cone. Copa..!!
I'm back. OK, one other option I've used successfully is hot glue. There of course is a catch, or two depending on situation. Because the cap is plastic you'll want to put the hot glue on the tip of something else, let cool down a little (very briefly), then attach, let set, then pull the cap out. The hot glue you might be able to pull off without re-heating, but I'd be more inclined to heat with a hair dryer and only a little at a time.
The other options have worked for me, though I do like a dental pick as opposed to a needle. One they come in really sharp tips AND the tip is usually curved. After that you can seal the hole with nail polish, model paint or silicon.
Cutting out is very simple if you use a FRESH exacto knife. I've made too many errors using a used knife. Never again. However, I'd search for a replacement cap first. No point cutting out the cap if you can't find a replacement.
Finally, and the timing is wicked funny, I just finished doing DCR's of my drivers and the tweeters are 3.0 (4-ohm).
Also, the woofers are 3.2 (4-ohm, wired in series), where the 301 drivers I received are 6.2 (8-ohm). I'll go ahead and use them, but will do readings with DATS first to determine which will go where (top or front). Likely the one with the better bass response will go in the front due to a larger "sub chamber" than the top. I'll post images with further explanations. I'll continue my hunt for correct replacements.
the hot glue came to mind-not robbing you of credit here. but I pondered its adhesive strength... I have two dental picks just as you've described. so I'll gingerly go for the cap avoiding the cone. these tweets have the dark grey cone, telling me they were in arid environment. Thx all.....!!! peace
No worries. Sick minds think alike? ;)
talk dirty to me...Sat I had a 30+ foot wild cherry fall all over the yard I spent all week cleaning, weeding, mowing, trimming, rant, bitch, rant...
No rest for the sick & wicked
No kidding. That sucks. Worked in Bellevue (near Seattle) WA and some years back there was a wicked storm that passed through. Not your typical storm either. Gusts around 80+ for quite a while. Next morning went into work and saw now less than 6 vehicles crushed by fallen trees. Mother nature sure has a wicked sense of humor.
By the way, what the heck is your avatar? Looks like a very cool vintage speaker.
Question for you all...
I foresee a bit of work here with my 601 speakers. So, wondering what people think about a separate thread "Bose 601 Restoration" which delves strictly into the repair/restoration of these speakers. I won't limit it with Series so that others could post similar "repair" related info. I would, of course, include technical stuff like T/S specs (after installing new surrounds) and such.
Or I can continue posting here. My logic is that people will read the title of this thread not thinking there is practical repair info and simply a conglomeration of opinions.
The other thing is a repair thread may not be as long (though could be) and will deal strictly with do's, don'ts, and any other tidbits that might help current and future owners.
Thoughts?
What say ye?
I say a new thread on restore-franken would be a good call. My avatar is a vintage Advent end table speaker.
Since I've caught my breath, question:
I'm reading ~4.5 ohms on the tweets. the cones look excellent, esp around the edges...doesn't appear to have any trickery applied. I haven't had time to test....is 4ohms sound about right?
So I don't have to go back and re-read, are your Series II or original? When testing the tweet did you disconnect one or both leads? I don't believe you can get an accurate reading if there is a connection to another driver (in series) or to the network.
not advent.. Altec
Damn fine looking speaker. Have a pair of Heath Kit Cabinets I have yet to do something with. Have just a 12" opening. Been thinking very seriously about making them subwoofers. Nice huge volume, solid construction, still on the backburner.
I have & run series l...but I also have one series ll speaker- and I just bought a pair of series ll tweets. so I'm reading the tweets out of circuit
Interesting. I'll do a proper check on mine and of course report back my findings.
While cleaning the tweeter cage on mine I discovered two tweeters with broken wires. So far the tweeters check out OK. I'm finding some stuff amiss, which full disclosure would have been the proper order of things from the seller. I'm not concerned since the tweeters are working.
we should kick the tires & slam doors on this old stuff some folks pawn off...oh well, welcome to the 'net! FireFall's Cinderella on the Bose...and I don't even need a Bourbon
Interesting. I'll do a proper check on mine and of course report back my findings...
While cleaning the tweeter cage on mine I discovered two tweeters with broken wires. So far the tweeters check out OK...
:scratch2:Did you check them just using a MM?
Thoughts?
What say ye?
I like the idea of a fresh thread. Just my opinion, easier than digging thru a generalized thread such as this.
