I can either send you surrounds (the surrounds themselves will run $6 each, and you just use plain Elmers glue or something similar), or I can do the whole job, for $25 per woofer.
I can't imagine why anyone would charge $70 EACH to do Boston woofers. Of course, if they're still swamped with business at that price, obviously SOMEBODY is willing to pay. Doesn't seem too sensible to me, from a customer standpoint...
In any case, the Boston 8" woofers are pretty darn easy to refoam, especially if it's the earlier paper-cone woofer. The later poly-cone drivers are a little more "picky" about alignment (tighter voice coil clearances), but even those are pretty much a cakewalk, compared to other stuff...
Also, be aware- if you've got the earlier paper cone woofer A60s... the new replacement woofers from Boston are ALL poly cone now... which will CHANGE the sound of an early A60 a bit. They're now using the same cone assembly (the one from the A60-II) in all the 8" replacement woofers. That's fine... except that the crossover in the second-generation stuff is slightly different, to tune it for that different woofer. I've used the replacements in the earlier stuff, and IMHO, I liked the paper cone woofer better than the replacements, by a slight margin. Other people may disagree, of course... it's an "editorial decision", really...
Regards,
Gordon.
