Retrovert
Addicted Member
Two problems with stacking speakers like this.
If speakers are to be stacked:
(1) When speakers are stacked the lower cabinet, a hollow chamber, resonates and re-radiates the input energy input, distorting the overall signal in the room. In this case it is like placing the speaker on the floor and having the structure of the house — floor, sub-floor, joists, and rest of the home structure — absorb, damp, frequency shift, and re-radiate sound energy. This, again, is distortion. The resonance points can cause dips or peaks in the overall frequency response, and because smaller cabinets tend to be thinner and less rigid, those points may be higher up in the frequency response.
(2) The cone of the lower speaker is moved, both absorbing sound and re-radiating it. Both are distortion. Such an outcome occurs whenever speakers are in the same room, of course, but in this case the baffles form a contiguous surface, coupling the sonic energy between the two baffles, first from the upper to the lower as the drivers in the upper cabinet emit sound, then from the lower to the upper as the sound is re-radiated by the lower drivers.
(1) Both speakers must have small sound-breaks (gaps) or isolation pads between the speakers to reduce the vibrational coupling. Isolation prevents the lower cabinet from acting as a resonant chamber, absorbing some frequencies and re-emitting at others.
(2) The lower speaker must have its cone covered to prevent it from absorbing and re-radiating energy because the baffles form a contiguous surface.
(3) The lower cabinet should be stiffened to avoid resonance, absorption, and re-radiation issues.
(4) The lower cabinet should be decoupled from the floor.
