Spent some more time on this over the last week or so and I think I'm ready for sanity checking... Drew up the load lines and figured the current that would be present at each tap on the power rail, adjusted the supply accordingly. Attached are the load lines I drew up for the various stages, and a PDF that contains the schematic for my the ridiculous power supply and one channel of the amplifier itself (there will be two). Yes, it does look quite a bit like an Eico HF-89. I think I have the gain of each stage calculated correctly (wasn't 100% sure about the differential pair inverter, but it seems plausible).
One thing I'm still not 100% certain about is the bias supply. I'd really like to be using larger grid return resistors for the 6L6GCs, but I'm wanting to keep under the 100K limit when the total resistance of the bias supply resistor network is included. As I understand, this is a bit fungible if I have sufficient current the bias supply, but I'm having trouble getting LTSpice on the Mac to give me current through 0V voltage sources.
