Yeah, that looks right.
Well, then it's just a matter of systematically breaking down the debugging into stages to see where the hum is introduced. Here's what I'd do to get started:
1. With all tubes in and the amp idling, measure the ripple at each stage of the power supply. Make sure you're getting the ripple rejection at each stage that you expect.
2. Take out both frontend tubes but leave the power tubes installed. Power it up and see what hum you are measuring on the speaker terminals with a proper dummy load installed. Should be nearly unmeasurable if output stage is working as it should.
3. Put the frontend tubes in. Because of the direct coupling between gain stage and inverter, if you put in the inverter tube, you must also put in the first stage gain tube.
4. Start from the input of the power stage and measure ripple/hum on the line feeding each of the power tube's control grids. Then move backward, i.e, if that looks noisy, move your scope probe to the output of the inverter and remeasure, if that looks noisy, move your scope probe to the input of the inverter, etc.
5. At some point along that chain you will see where the hum/noise is introduced. That tells you where to focus to eliminate it.
A couple of obvious things:
- Based on whether you measure 120 cycle hum or 60 cycle hum will give you clues where to focus.
- Make sure filament circuits have proper ground reference.
- Double check all solder joints by taking a pair of needle nose pliers and gently tug on each wire on each connection point. If you suspect any marginal joints, resolder them.
- Measure all resistors to ensure they are indeed the correct value for the location.
- Make sure the chassis is grounded to the audio circuit ground--at one point only.
- Probably easier to bypass the input jack and volume control, and jumper the 12AX7 grid right to ground for these kinds of tests. You may also want to temporarily eliminate the CCS in the inverter and jumper in an appropriate sized fixed resistor. In other words, look for ways to simply the debugging and eliminate anything you can that adds complexity.
- Do all these tests totally open loop--no feedback or HF tuning.
- If your scope does not have an AC setting on it (not sure if digital storage scopes do or not), you can "simulate" one by hooking a 0.47 uF or 1 uF 1000V film cap in line between the measure point and the positive hook of your scope probe. Make sure the negative side of the probe is hooked securely to the audio circuit ground. That way you can continue to use your 1x probe for max resolution.
- For this debugging, try both disconnecting and connecting the third prong power cord ground from the chassis.
Somewhere along that process of debugging you will see where the hum is introduced. In 90% of the cases where I've done this, it's either a missing ground connection, a faulty solder joint, a ground reference not provided or faulty, or noise being picked up from test leads/jumper cables or amp wiring. The other cases were bad tubes.
