Okay, hooked it up to the scope and some dummy loads for some initial tests. No NFB or HF tuning currently connected.
First, voltage measurements. The AnTek PT supplies a bit more juice than my original power supply design, so voltages are running a litter higher than I'd planned for / calculated, but not especially so:
- At first filter cap: 427V
- At second filter cap (OT supply): 420V (vs 410V)
- At third filter cap (inverter supply): 411V (vs 400V)
- At fourth filter cap (AF amp supply): 207V (vs 200V)
As for a few other key measurements:
- AF amp idle plate voltage: 134V (vs 125V)
- Inverter idle plate voltage: 284V (vs 279V)
- Inverter idle grid voltage: 134V (direct-coupled to prior stage)
- Inverter idle cathode voltage: 139V (vs 130V)
- Output idle plate voltage: 413V (vs 406V) -- output is ultra-linear connected, so idle screen voltage is essentially the same.
Of note is the inverter... because the cathode is connected to a CCS, which I had pre-set to 9mA (which I verified is still correct), the inverter is likely biased slightly cold for the slightly higher plate voltage. More on that later.
Also balanced and set the output tube bias to 53mA, which gives me -35V on the grids of the outputs. Some are a little higher, some a little lower. I have a bunch of these tubes, so I should shuffle them around looking for better matched pairs.
I connected my function generator to one channel, set it for 1KHz, and adjusted until I saw clipping on the output, and backed it off ever so slightly until the clip went away. 42.8Vpp, which is 15.1Vrms, which into an 8 ohm load is 28.5W.
I backed down the output to 40Vpp, then checked the input: 320mVpp ... Open loop gain is thus 40 / .320 = 125. That's pretty close to what I approximated for the 8 ohm tap (137), based on eyeballing the load line of the output stage. Taking the measurement on the 16 ohm tap (were I'll be taking the feedback from) while an 8 ohm load is on the 8 ohm tap I get 56.4Vpp, so 56.4 / .320 = 176, which again isn't terribly far off my estimation of 196. But this does change my feedback calculation somewhat. Leaving the circuit as-is, I'll have -11dB instead of -11.6dB.
To check the voltage swing to the output tubes, I set it to max power and connected the scope to the grid of one output tube. I get 68Vpp. At 71Vpp, I start to see the peak of the wave clip, while the valley maintains its shape. This is why I suspect the inverter stage is biased incorrectly. I also notice that one of these GE 6SN7s has a weaker half; this probably also explains why the valley of the output clips before the peak does. Guess I should tube roll before I really dial this thing in.
1KHz square waves @ 1W aren't terrible looking. Again, pre-feedback.
Connected to speakers, it sounds pretty good with music playing though it. I played my usual test tracks and they all sound good at low and high volumes.
I am noticing some noise coming though the speakers, though, and I caught a glimpse of it on the scope. After hearing it, I decided to look at it on the scope with no input signal. As you can see from the photo (#1), it's not hum. The sound is a very regular sharp popping sound. Some of it is definitely environmental noise -- which I switch off my (LED) desk lamp, the small "beads" in that wave form go away (photo #2, #3), but the large spikes remain. As you can see, it's worst with the input pot set at max (photo #4), but certainly not awesome with it set at min (photo #5). It's cleanest with the input put set at about 25%. It's definitely present in the signal coming FROM the phase inverter (measured at the output tube grids). Not sure how I can measure the signal being sent TO the inverter, since it's direct-coupled. (I'm not even sure if it's "safe" to pull the first stage tube out, because it's direct-coupled to the inverter.)
