I'll have to go through and write them all down but I'll try to do that tonight.How does the other voltages of the right channel compares to the published schematic?
That was quick! Hopefully someone smarter will weight in
I see you replaced C814 with WIMA, so we can rule that one out.
Did you check the protection circuit (BL to EL)? Maybe the germanium diode D903/D904?
Here are the right channel voltages (in red).
And the left channel for comparison
Thanks! I did see that post when I googled how to adjust the protection circuit at some point in the past. The best I can tell, it's working as designed but I've been wrong about lots of stuff before.@sregor has a nice explanation on how the protection circuit works.
https://audiokarma.org/forums/index...mode-at-moderate-volume.981671/#post-15275564
I have done the service manual alignment. Before recapping, the left channel aligned pretty well but I wasn't able to get the top of the sine wave to clip at all on the right channel. After recapping, I was able to get the top and bottom clipping equally on the right channel but there's still about 3 fewer watts of output on the right channel, and about 5 volts less DC on the right channel.Probably DC voltages are closer between channels after adjusting VR801 and VR802 for max unclipped output, as per the service manual.
I hadn't considered checking it without a dummy load. I've only done it with them connected. The DC difference exists with the volume all the way down and idle current set at 23mA too if that helps?ok, have you considered to see if there is a difference for clipping having a dummy load connected and the same for having it not connected?
Since I am thinking about the base current (for tr806) you will need to provide the current into the load. If the driver transistor (on positive side) and the output transistor would both have quite low HFE, one can have a problem converting the few milliamps of base current of a driver transistor into the two amps or so peak the output transistor has to deliver into the load.
(just thinking out loud...)
I was not thinking big enough for substitutes I guess. Thank you for the help there. Before I order those and a couple of their complements, I might swap the finals, left channel ones to the right channel and vice versa, just because that's easy to do and will help me rule them out.The AU-555 service manual lists 2SC734 (O,Y) or CDC8002-1 for TR806; KSC2383 was a suitable replacement for the latter in a AU-555A restoration.
