desertrat748
What we have here..Nice Cool Hand Like reference!
Thanks for clarifying. Rather than risk damage, on the occasions when one of my sons brings a laptop for source music, I'll just switch in the Topping DAC and live with the lower fidelity.I would probably not use that as it will create a +5v conflict. For example, the power supply will see the +5VDC from the other source device. Also you will get any noise from the digital source which will limit performance.
Now if you remove the insulation and clip the power wires going to the USB connector that is attached to the other device, then it should work fine as all the power for the C100 must then come from the attached and adapted power supply.
Actually looking at the picture more closely and digging a bit more, it appears that adapter is made with the intention of providing power through one side and data through the other. I didn't see the little labels on the thumbnail for each of the female connectors. Does the green light turn on if no power is provided through the "PD100W" port even if the source device is plugged in?Thanks for clarifying. Rather than risk damage, on the occasions when one of my sons brings a laptop for source music, I'll just switch in the Topping DAC and live with the lower fidelity.
Yes. I plugged the PC into the audio headphone input, and disconnected the PSU. The greenlight stayed on, and the music continued to play even without the outboard power supply plugged in. I'm a little surprised....does that mean there's a 5V conflict going into the outboard PSU?Actually looking at the picture more closely and digging a bit more, it appears that adapter is made with the intention of providing power through one side and data through the other. I didn't see the little labels on the thumbnail for each of the female connectors. Does the green light turn on if no power is provided through the "PD100W" port even if the source device is plugged in?
Not sure. Sounds like there might be unless there is some smarts built in that senses voltage on the power line and switches the other input voltage off. Hubs are smart enough to regulate the voltage correctly, but I'm not sure about that adapter.Yes. I plugged the PC into the audio headphone input, and disconnected the PSU. The greenlight stayed on, and the music continued to play even without the outboard power supply plugged in. I'm a little surprised....does that mean there's a 5V conflict going into the outboard PSU?
Maybe I could measure the voltage on the power input side when it's unplugged from the PSU... Assuming a measurement of 5V there would indicate the potential problem you mentioned. Either way, it's not worth the risk to me...I'll just unplug the PSU, and let it run off the PC when the time comes.Not sure. Sounds like there might be unless there is some smarts built in that senses voltage on the power line and switches the other input voltage off. Hubs are smart enough to regulate the voltage correctly, but I'm not sure about that adapter.
Here's where the trouble part comes in to the story. The signal started cutting out randomly for about 2 seconds. The same disc might play perfectly one time and cut out 5 or more times on the next play. This does not point to defective discs.
Sounds like its either:If the SU1 is indeed defective I'm very happy I didn't start the surgery, which would have voided any warranty.
They skip out on a lot of parts. I have an SMSL and the chassis sits above and shorts if I put it on other equip.Well, the SU-1 is defective. I substituted a $13 dac for it and although it sounds like a transistor radio it works perfectly. I'm in contact with Apos to rectify the situation. I am surprised that an electronic item with no moving parts can come out of the factory defective. Law of averages, I guess.
Nice to know the return was straightforward. I've heard that from others about Apos as well.Customer service from Apos is first-rate. They emailed a prepaid shipping label and will refund the purchase amount.
The second one arrived today and it cuts out just like the first only more frequently! Major issues at SMSL!
Either way, huge bummer! Yes, hope you can bag a decent one.Might have run into a bad bunch of chips or maybe some issues with cold solder joints. Obviously a bad production run. I just hope I can get my hands on a good one!
I’m not trying to be negative here or sound rude in any way but I don’t think it’s the su-1 at this point.The second one arrived today and it cuts out just like the first only more frequently! Major issues at SMSL!
