Whisper04200
Haven’t gotten the PDF, decided to say screw it and see if it was self explanatory if I took the front panel off.
Installing the new bulbs was a breeze, took all of 5 mins. It’s wild, looks like the originals had never been replaced. And this is a 52 year old amp.
Replacing the blue filter elements for the meters is a different story though. For anyone considering doing this to your McIntosh that has similar blue meters, be aware that it is not just a remover and replace job by dropping in the new piece of filter- these puppies are wrapped around all four corners of each meter, and will require some careful work on your part. I’m going to hold onto the filters that came with this kit until the next time I have to take the amp into the shop for maintenance and have someone qualified do the installation, I don’t want to mess this thing up beyond repair.
So I guess that’s one semi + review for hifiaudio- took longer than they should have to ship, minus 10 points for not including the instructions in the kit, another -10 for being misleading about “only needing a screwdriver” to install everything, but +10 for sending replacement bulbs that fit and work.
