Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I am working on an akai am uo3 amplifier and I need to replace the stk 0040 ii power amplifier ics but I can only find stk 0040. Are these fine to interchange?
Not the same design but in many cases it is possible to sub. I’d have to look at the Akai design in more detail to be certain.
Not too sure about the quality of the knock off stk these days so that is why we designed a discrete stk0050, check it out in the pioneer section under stk0050 for a sx-780
Not pin to pin compatible. The STK 0040II and STK 0040 are different circuits. Check the STK datasheets. You need to study the schematics and determine the changes needed to use one in place of the other.
