Can't find that warm sound I want.
I stayed in an airbnb a while back with a pretty basic marantz amp and table(not sure which) and some advent speakers. The sound I heard out of that system was magical to me, like a warm hug for my ear holes. After that I had to build my own system. I posted a few questions on Audio Karma, did a lot of research and ended up with a pretty kickass setup....but it doesn't sound like that warm hug I wanted. I tried to get ahold of the airbnb to ask about the setup but can't get in contact. Maybe you guys can give me some advice based on what I have now as to what I need to replace to get the warm sound I want.
Currently I have:
Sansui 7070
Mitsubishi LT-20
MMC 20CL
ADS L520's
What kind of inter connects and speaker wire are you using? Cardas imparts a warm sound to a system,they roll off the hi frequencies of your system the way tube equipment.does. Buy used. The same with 1st generation Monster cable,the M1 would be a good place to start.
Good points...
I see a lotta love for Advent and Dynaco ST-70.
Not the amp currently in my rotation but my ST-70 reproduces female vocals "to die for". It's a keeper and I'm very proud of the restoration job.
System Synergy is the key. Listening room, speakers and the power to drive your speakers.
Can't go wrong with an ST-70. It's a classic EL34 tube amp.
Buy yourself a set of suspension speakers like these with 8 inch drivers which frequently sell for about $99. Then get an entry-level receiver and turn the bass control all the way up and run that receiver on the direct mode. Lastly, purchase a cheap turntable and play some half dirty, semi warped records, I think you will achieve the warmth and sound that I had circa 1974 with a pioneer receiver, and a set of small Advent speakers. It was magic
https://www.amazon.com/Yamaha-NS-6490-Bookshelf-Speakers-Finish/dp/B00018Q4GA
I guess I'm trying to figure out where the loose link in the chain is. Is Sansui 7070 considered warm? Like if I get different speakers will that fix the issue? Or does the problem lie more in the amp?
The speakers ...not a weak link, but it was the Advent sound that you were hearing ..
Get some Advents ..
Lacking Advents..
Move what you have around to different positions in the room ..
And make sure that the room has lots of soft materials in it ... rugs .. drapes.. wall hangings ..soft furniture .. etc.
The room, the room, the room .. It has a big impact on what you're hearing ..
Dynaco and Advents is a nice pairing.
Get some Advents ..
Lacking Advents..
We have a decent sounding room, which got a lot better when we added pleated blinds to the corner picture windows and drapes to the patio door. The Advents are a nice size for it; large enough to mean the business, but not overwhelmingly so. Ours are in good shape and the grills still look fresh, even though they're from 1976. Pulling the listening couch away from the back wall helped the bass response.
