Biotracers and other servo controlled arms are always bad with warps. The servo control adds damping, and that automatically means the arm follows warps more slowly, resulting in higher VTF on the up ramp and lower VTF on the down ramp. If the electronic damping is too much, or the down ramp too steep, the stylus can loose contact with the groove.
Adding a system like the audio technica AT666 vacuum platter can solve those warps. However, that platter is 9,5mm thick, so a VTA adjustable arm (usually set to it's top position) and removing the rubber mat is a desirable setting if you want the SRA to remain within reasonable specs.
