The long story is this; I did a close inspection and found that the lens at one time had fallen out and someone put it back in place and glued it. I removed the lens to make sure there was no obstruction. I then cleaned it, both sides, and put it back in with a scant amount of glue to hold it in place. The result was the same as it was when I first tested it. It will pick up each disc and then stop. The lens move and the disc does not spin.
