I'm guessing these W121 could be from an old 280SE? The seller "didn't remember"
Here's a quote from someone else who has given me some interesting "insight" recently, I have invited him to join in... "One of the best things to improve sound is brace the inside of the cabinets. I have a bunch of old oak hardwood floor boards I use for this. I use PL Polyeurathane and glue in cross braces and 45 degree angles everywhere inside the cabs. Seriously, it makes a big difference. Box resonance really slops up the sound. Get those boxes solid like concrete blocks, and you'll hear the difference!"
I'll know what I need to do as soon as I put that Grand Funk "RED ALBUM" on!!!!!!!!!
When Mel gets on a roll with the Bass!The last set of speakers I recapped where some old Jensen's Pr200's I used Dayton Audio (Parts Express) Poly's, expensive and physically larger than the originals....but worth the extra money... They sound great! It's age and heat that kill caps, they don't last forever the values start to drift. Go online and look up how to read your Capacitors value and polarity. There are many less expensive options out there for caps. If your speakers sound good you ....leave them alone, and save some money. I have some Speakers that use Quality Caps originally that I have not changed.If I DO need a cap or two, any suggestions for brand/type/value? I'll check them first, but pretty easy to just upgrade., too. I thought they actually looked to be in good condition. I did hook up one of the Radio Shack piezo tweeters to my Model 26 cab to try it and a thought a swarm of locusts were attacking!!
Hi. This is the guy you were talking to that talked about cabinet bracing. I use scrap oak flooring boards, so other than a tube of PL construction adhesive, bracing doesn't cost anything if you have some scrap wood. I've found it makes a big difference. As to some of the other comments: I agree you shouldn't add a resistor to modify driver impedance. I forget technically why, but I remember reading why and retaining that it won't work properly. I'd have to disagree that the dustcap size effects sound audibly, or effects cooling. I think it's just asthetics. As for driver resistance/impedance, resistance is what you measure with a meter (dc), but that goes up and down quite a bit based on frequency (ac). Impedance is kind of the average resistance the amp sees as it's driving the speaker. Usually measured resistance is about 3/4 of impedance, so if you measure 3 ohms resistance with a meter, it's considered a 4 ohm woofer. If you measure 6, it's an 8. Roughly. On frame sizes, cerwin mostly used the same frame sizes, but not all. There are two different 10" frames, and they were used on two different production runs of the same model woofer. I wish I could remember the model. Also, the new aluminum frames like the xls series are now different (larger) than the older frames (at,vs,ls, etc) As for amps handling lower impedances, mostly agree. However some amps, when using both A and B speakers, internally run them in series. You can tell if yours does this by switching in the B speakers (with no B speakers connected). If your A speakers turn off, it does this. Usually it was cheaper amps/receivers that did this. Doing this does protect the amp, although it also can limit the watts you get out of it. As for securing the T-nuts that fall out of the crumbling particle board. Put the t-nut in place. Then take a screw of the same thread size, coat it with grease, and thread it into the back of the nut a bit from inside the cabinet, then take PL construction adhesive and smear some on the back of the nut. Once it's dry, the greased screws will back out, leaving those t-nuts nicely glued in. And back to amp power, high watt (like over 150 wpc) "home" amplifiers get expensive. It's kind of another world switching to pro amplifiers, like Crown, or Behringer, etc. I still use a Nad for my "best" system, but I use pro amps for my "test" systems, and it's night and day. Pro amps, for the money, are incredible. More power than you can dream of. You can get this kind of amp WAY cheaper. And they are often 2 ohm stable. You have to make sure it accepts rca inputs (many don't, and many do but it's hard to tell because they have a "combination" input jack on the back that doesn't look like a rca jack but accepts an rca to 1/4 jack for unbalanced) The ONLY problem running this kind of amp, is that you're going to start blowing drivers. Really. These things have basically UNLIMITED clean power, and Cerwins will take it and sound amazing right up till PFFFTT! Recone time. Another good amp option are commercial power amps, like Biamp and Bogen. Made for like the ceiling speakers at JC Penny. But these amps are also often cheap (since no one knows what to do with them). Often you have to convert the terminal strip input to rca, but these things are tanks. I have a pair of Bogen 250's. Solid 250 watts, they weigh more than my car and are designed to run flat out full power till the sun burns out. Beefy stuff! Also have a Biamp CPA 650. 325 solid watts per channel, got it for $90. Cerwins do really well with a lot of power. Just be ready to do some reconing, especially if you drink.![]()
Hi. I've never seen a ribbed 121-4. I'll bet it was reconed with an ATW-12 kit (for the AT-12). They might have existed, but I've never seen them. You could always get one more and recone them both to match. The L121-4 came in both 4 and 8 ohm versions and you can still get recone kits for either.
I've never tried deadening steel baskets, but it makes sense. It might help, and (with one exception) it can't hurt. Basically you just need to add mass. Whether it's Dynamat, putty, epoxy, or gluing on chunks of car tire rubber. Just one thing, make sure it's on good. Imaging if you were jammin away and a chunk-o-somthin fell inbetween the cone/frame/spider. Ouch!
That ribbed L121-4 was virgin when I got it a number of years ago. It had what was left of the original CV surround, which is completely different than the foam surrounds you can buy today. Though it is possible it had been reconed at one time, it would have been ages ago.Hi. This is the guy you were talking to that talked about cabinet bracing. I use scrap oak flooring boards, so other than a tube of PL construction adhesive, bracing doesn't cost anything if you have some scrap wood. I've found it makes a big difference. As to some of the other comments: I agree you shouldn't add a resistor to modify driver impedance. I forget technically why, but I remember reading why and retaining that it won't work properly. I'd have to disagree that the dustcap size effects sound audibly, or effects cooling. I think it's just asthetics. As for driver resistance/impedance, resistance is what you measure with a meter (dc), but that goes up and down quite a bit based on frequency (ac). Impedance is kind of the average resistance the amp sees as it's driving the speaker. Usually measured resistance is about 3/4 of impedance, so if you measure 3 ohms resistance with a meter, it's considered a 4 ohm woofer. If you measure 6, it's an 8. Roughly. On frame sizes, cerwin mostly used the same frame sizes, but not all. There are two different 10" frames, and they were used on two different production runs of the same model woofer. I wish I could remember the model. Also, the new aluminum frames like the xls series are now different (larger) than the older frames (at,vs,ls, etc) As for amps handling lower impedances, mostly agree. However some amps, when using both A and B speakers, internally run them in series. You can tell if yours does this by switching in the B speakers (with no B speakers connected). If your A speakers turn off, it does this. Usually it was cheaper amps/receivers that did this. Doing this does protect the amp, although it also can limit the watts you get out of it. As for securing the T-nuts that fall out of the crumbling particle board. Put the t-nut in place. Then take a screw of the same thread size, coat it with grease, and thread it into the back of the nut a bit from inside the cabinet, then take PL construction adhesive and smear some on the back of the nut. Once it's dry, the greased screws will back out, leaving those t-nuts nicely glued in. And back to amp power, high watt (like over 150 wpc) "home" amplifiers get expensive. It's kind of another world switching to pro amplifiers, like Crown, or Behringer, etc. I still use a Nad for my "best" system, but I use pro amps for my "test" systems, and it's night and day. Pro amps, for the money, are incredible. More power than you can dream of. You can get this kind of amp WAY cheaper. And they are often 2 ohm stable. You have to make sure it accepts rca inputs (many don't, and many do but it's hard to tell because they have a "combination" input jack on the back that doesn't look like a rca jack but accepts an rca to 1/4 jack for unbalanced) The ONLY problem running this kind of amp, is that you're going to start blowing drivers. Really. These things have basically UNLIMITED clean power, and Cerwins will take it and sound amazing right up till PFFFTT! Recone time. Another good amp option are commercial power amps, like Biamp and Bogen. Made for like the ceiling speakers at JC Penny. But these amps are also often cheap (since no one knows what to do with them). Often you have to convert the terminal strip input to rca, but these things are tanks. I have a pair of Bogen 250's. Solid 250 watts, they weigh more than my car and are designed to run flat out full power till the sun burns out. Beefy stuff! Also have a Biamp CPA 650. 325 solid watts per channel, got it for $90. Cerwins do really well with a lot of power. Just be ready to do some reconing, especially if you drink.![]()
Right? I was planning on looking into deadening with the "Moongel" stuff. I've seen a few drummers use that stuff in their snare drums.
Well I received my "new" midrange FM-6 speakers today, and they are too big. I thought I read somewhere those were used in U123/321 1230???? These holes are 5 1/2" apart cross speaker, I need 4 1/2". Anybody have a suggestion what the correct midrange might be?
Well, now I have probably enough extra speakers to build a set of D5, just in case I find a set of empty cabs.
Whoops, hole cutout is 3 5/8", probably exactly 1" less than needed for the FM6 I just got. I'm going to research the M5 now, I'm going to guess I need the 5" version in these cabs if I want to avoid cutting. So a 1230 (at least mine) has a 5" midrange, not the 6" the U123/321 seem to have (unless that varies, too??).Probably all 1" VC.
