Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Any cleaning you do is going to be risky. I would probably use plain water on something like a cotton swab (though something lint-free would be better), and try to clean between the decal markings, and try to avoid touching the back of the decal markings.
A steady hand will help prevent damage.
It will be interesting to see if anyone has a better suggestion. I don't think anyone is going to be able to come up with anything that will be free of risk.
Before I risked it, I would put that dial glass on a flatbed scanner and scan it to a file at 1:1(front and back). You could then get a new decal made to stick on the glass.
One can get new decals to put on glass, though it would not be the same. Radio Shack used to sell such things (I think I still have some from years ago), though I am not sure where one would find them today. Certainly, the ideal is to not damage the old decals and not need to find anything to replace it. But it is within the realm of possibility, depending on what, exactly, the decals are like.
I thought I would follow up with what I did that cleaned well.
I ended up just fogging the glass with my breath. Just like cleaning your glasses in a pinch. It got things just damp enough to remove the dirt. It was not so damp as to loosen the decal. It took a few tries. It came out as clean as can be with no decal damage.
I have a few smeared numbers on what was a perfect Sherwood S-7000 dial from touching it with a damp cloth. Some of them are fine, some disintegrate if you look at it too hard. I guess age and what the original print was factors in.
