Cleaning a receiver
Isopropyl alcohol would probably work and is cheaper. CRC QD looks safe, but it does contain petroleum distilates, so be careful using it.
Alcohol, Q-tips, a 1/2" paint brush with the bristles cut down so they are fairly stiff, shop towels, and a LOT OF PATIENCE!
Blow it down with Air first, then vacuum with a bruxh on the end.
Using the alcohol and brush paint a section and work on it until it's clean. Turn on it's side and high to low. Use the Q-tips for itty-bitty access areas.
DO NOT GET ANY CLEANER IN, ON, within 1/2" of the TUNER CAPACITOR. Just blow it out.
Lastly. Use a non abrasive metal polish to shine it up. Or not depending on your preference.
Larry
Just because I have also thought of cleaning a couple of my receivers (and I don't know what everything is exactly in there) what is this part that you speak of (tuner capacitor)?
The Tuning capacitor is the 1/2 moon shaped fin assembly, with a tuning wheel on one end. Follow the string from the dial face to the wheel.
