Crosley Spin Clean
If the only difference is the shape of the tank I'd be inclined to go with the Crosley. $60 is still a lot of money when you can wash records in the sink for next to nothing just having to purchase paint pads.
Use this to wash the really filthy ones in Dawn solution before a rinse and them the Spin Clean ans a vacuuming.
I think it's best to have a solution that contains a flocculant for this type of cleaner. I would not use home brew for this. The question is, what type of cleaning fluid does the Crosley have?
Jon
Jon
What is a flocculant? Something that gets dirt the floc off your records?
Monty, I don't know if you're serious or just messin' around?
If you're serious I'll tell ya!
If you're just messin' around, then get the floc outta here! :D
Jon
Jon
Google is out there, but I'd rather hear it from you. :D
So, you're not just messin' around, you're messin with me. :D
Ok, the flocculant causes contaminants to clump together and create a floc. The floc will then either float to the top, or sink to the bottom. The one in the Spin Clean sinks. If you have a Spin Clean you will notice these clumps as kind of a cloudy mass at the bottom. I tend to rinse my LP's off before using the Spin Clean to allow the cleaning of more LP's, since the flocculant gets used up.
This is the simplistic version for simple people. :D
Jon
FYI. If you recall the scene in Ghost Busters when they get slimmed? That's probably a concentrated polymer flocculant. I had that happen to me once when the wind kicked some up in my face. It is in fact very slimey.
Think snot!
Jon
Jon
You calling me simple? :tears:
That's what I expected, more or less. I do have a Spin Clean and know about the effect.
So what about readily available flocculants that can be used in a DIY solution that is cheaper than a proprietary store bought version?
I wouldn't call you simple to your face. :D
Readily available, I don't know where you could get some.
You don't expect me to Google this for you do ya? :no:
Jon
I've got it, a place that sells pool supplies!
Oh wait, they don't have pools in Canada, or Vancouver Washington either. :no:
Jon
Jon
We call it "ocean". :yes:
Yeah, already looking at alum and other substances. I'm not looking to undermine Spin Clean (or Crosley) but it's just handy info. :smoke:
It didn't occur to me to make a home brew version for the Spin Clean, but why not? You just need to find the right flocculant. I'm not sure what else might be in their solution though??
So which is it, Canada or Washington?
Jon
I don't want to get off on the wrong foot here being the new guy, but unless there is some magical effect I don't see, the Spin Clean and the Crosley are basically the same product. When you compare: the inside reservoir, brushes, all notches, rollers and lid are the same. The insignificant differences are: the outside stand and that one is bright yellow Vs a darker color. Whoopty-doo... yes, you can see the dirt in the lighter color, but just because you can't see it, does it mean it's not there?? The sole factor, perhaps the ingredients of the cleaning fluid, may be different... that's about it. :yikes:
Besides most of us have our own recipe for cleaning fluid.
