Myvinyl333
Can you run a pair of Pioneer CS 99 and CS 99A via A & B speaker outputs on a Pioneer SX 1010? I am also looking at adding a subwoofer but not sure how to connect the sub< Thankss
I was going to put 99 on the bottom and 99A on top? is there a concern with 80 watt to 100 watt?
You should be able to connect both pairs and run at same time. I do not know about subwoofer. I personally don't thing subwoofer is necessary.
Well cubdog look at the list of Pioneer speakers I have. The speakers he has have large woofers. I said "personally.." Don't understand why you are dogging me, oops that's your name.
To NotJerry - You can hook up both sets of speakers and play at same time. You can stack them if you like. One issue might be if one set is louder than the other. You just need to experiment with placement to see what works for you. Don't worry about wattage label.
How would you know if a sub is necessary? You haven't heard his system, in his room, so you are only speculating how it might sound. With nothing to go on, and no evidence why bother? :scratch2:
cubdog
What is the minimum impedance of the receiver? You can find it written above the speaker outputs. It may say something like "Speakers A OR B- 4-8 ohms. Speakers A+B 8-16 ohms". Make sure the speakers don't go below that.
And no, wattage won't be a problem as long as you don't play them at full volume for long periods of time.
I apologize for not posting what I am doing. I have hooked a sub two B speakers on the 1010 and stacked the 99A's on top of the 99's.
I have found as many have that the 99A's are short on bass. You would think with the large woofer it would be the opposite? With sub it is much better and with the 99A's more @ ear level the mids and high are much more pronounced.
Now I want to add the 99's and see what I get. I feel the 99's have more bass but I am not sure.
I am having a problem connecting bare wire to the speaker terminals on the 99's.
No need to apologize. I had a feeling you might find your speakers lacking in the bass department but as I stated it doesn't do any good to speculate. Every room, every system, and every set of ears are different. Good luck getting things sorted out.
cubdog
