Bill Murray
Under What's new>latest posts............???
I'm not seeing your post ..
It's not a "post" he created another thread???
Bill you created a thread not another postUnder What's new>latest posts............
Not really a forum guy any more than I am a DAC guy. Always doing the wrong thing. Post? Thread? Don't know the difference between them.Bill you created a thread not another post
You will. You definitely will.I'm sure there are more expensive ones out there but I have no desire to find out.
I decided to connect my MacBook Pro (M1) to my Marantz. Sounds pretty darn good. I still think vinyl sounds better.Correct me if I'm wrong, but wouldn't Apple Airplay solve this problem? I don’t Apple anything.
I did find a DAC that works for me. The one in my CD player.^ A thread consists of multiple posts, so for example this is one of my posts in this thread.
Anyway here's hoping you find a DAC that works for you and for what it's worth I went with a $99 Schiit Modi several years ago and to my ears it sounds fine I'm sure there are more expensive ones out there but I have no desire to find out.
You're mission accomplished!I did find a DAC that works for me. The one in my CD player.
That’s one small step for a man, one giant leap for mankind.I did find a DAC that works for me. The one in my CD player.
Doubt it.. Obviously there is a difference between a 40 year old corroded cable and a brand new one ...
Fact is that many people use 10x (or more) money on DAC's then they should need, for a audiophile it's no problem to use 10x more money, also on thing they don't manage to hear any difference on (same **** with cables).Going to that fool's site is some of the worse advice that could be given to someone trying to understand digital. That's like shopping for advice on Redit or asking around Wal-Mart's automotive section for DAC advice. There is a reason that the so-called science site is so discredited.
Ranking devices by numbers is not how music is made. Music is when you play a song...then another song and forget to stop because you are totally captivated.
The sterile alternative that comes from focusing on one bench parameter is to start one song...then cut over to another cause you saw it in your play lists...then another...try turning it up...then down...and shortly remember you have something else to do. That's what buying based on a flawed ranking systems will buy you.
Look for music...not just numbers.
EV3
Count me as one of those fools who can hear a difference between DACs and CDPs—and even sometimes cables.Fact is that many people use 10x (or more) money on DAC's then they should need, for a audiophile it's no problem to use 10x more money, also on thing they don't manage to hear any difference on (same **** with cables).
If you want to be a fool, then you are welcome to be that, that's your own choice. Some people have spend hell of much money on foolish things, When it cames to DAC's, after cables that is the dumbest thing to use much money on... Put the money in to better speakers or a better amp in stad, that give better result wich a new DAC's never can give.
With right amp and speaker then a old and very cheap CD-player (without a external fancy DAC) could play amazing, the most expencive DAC's out there could never give a good result on cheaper amp's and speakers.
I guess I'm proud to be a fool then. Since you're not me, you're totally unaffected. Here's another analogy. If you want to be cheap but can't admit it, you are welcome to be that. Some people have never spent much money on audio equipment and will never realize what's possible. I consider that to be somewhat foolish, especially when they can afford more.If you want to be a fool, then you are welcome to be that, that's your own choice. Some people have spend hell of much money on foolish things, When it cames to DAC's, after cables that is the dumbest thing to use much money on
I bought a SMSL C100 to connect a 4k TV, Windows PC and a Denon DVD 2910 to a pair of ZA3 amps. I needed to have remote capability or I would have bought the SU-1. I heard improvement compared to the TV and computer analog outputs but very little difference, if any, compared to the 2910. I might buy Fosi's new ZD3 mostly for it's balanced connections if it gets good reviews.I recently bought a SU-1 DAC to connect a PC to my stereo system via USB. I went ahead and compared it to the DAC in my 30+ year old VRDS-20 CD player. I could not hear any difference via my speakers (not so great) or my electrostatic headphones (GREAT!). Both the SU-1 DAC and the VRDS-20 have been thoroughly measured at audiosciencereview.com. The SU-1 measures much better than the DAC in the VRDS-20. That led me to conclude that my ears are incapable of hearing any differences that may exist between them, so I won't be spending any money on more expensive DACs.
