bimasta
Addicted Member
When I got my DP80, all 5 screws were tightened down hard, on each of the 3 springs. It came like that, so I assumed it was right. Now I'm sure it's not right.
What is the point of using springs if they're all adjusted tight, with no give? It's like joining the 2 parts of the platter like a single piece of metal — Might as well just use one piece of metal for the entire platter, in the first place. Why 2 parts?
The 2 parts have different functions — the bottom fits onto the bearing-and-motor, it's heavy and has most of the mass.
The top part is much lighter: it's just a surface for the LP to rest on.
And it's supposed to be de-coupled from the bottom piece. That's why the springs are there. The bottom-platter gets all the Bearing Rumble and Motor Noise, which will resonate through the Vinyl and be picked by the Stylus. The upper-platter is supposed "to float above it all", and present a non-resonant surface for the LP — that's why the foam pads are added: to damp residual resonance that makes it through the leaf springs.
I adjust the leaf springs as follows. The middle screw is tight (Screw 3). As Legrace notes, it came from the factory with an "alignment seal". It was, and must be kept tight.
But should the other 4 screws also be tight?
The two outer screws (1 and 5) must be loosened in order to center the Upper Platter within the mass of the Lower Platter, or else the platter will spin "wonky". Once centered, then 1 and 5 are tightened hard so it remains centered.
I leave Screws 2 and 4 loose, so the springs can act like springs, and "give". They can damp some of resonances excited in the lower platter by the bearing and motor.
The DP80 platter is designed like a "sprung" turntable, e.g. Linn and Thorens, which bounce a little — the springs in a belt-drive isolate the Platter+LP+Stylus from the noise of the Motor.
You can't isolate a DD's platter from its motor (like you can with a belt-drive) because a DD's platter is part of the motor. So Denon designed it all into the Platter — and the top part of the platter is supposed "give".
