House de Kris
Loud-n-Deep
All AR speakers were made with 18g internal wiring.
This may actually be a good "first approximation" place to start when choosing speaker cable. Although, I don't know how many people are willing to open up their speakers to check the internal wiring. If we assume AR chose this because it is "good enough" to get the job done, then we should at least arrive at a "good enough" setup in our home. If the internal 18ga wire is only a foot long, and you desire your speakers to be 10 feet from the amp, then you only need to select a wire that has 10x cross-sectional area. That way, the losses of the interal wire are identical to the losses external to the speaker. In this case, a wire with 10x cross-sectional area of the 18ga is 8ga. So, if you want to wire your ARs to your amp 10ft away (and they only have one foot internal), 8ga is a good place to start. If you desire your stereo to be any better than "good enough," like you strive for a superior audio experience at home, then you'll probably want more copper in your cable than 8ga will give you. If you have a notion that L and C play any sort of role in a cable, then the topology of the cable will be of very great importance.
I have bigger fish to fry. I want Martin Logan ESLs, I want to build an OB system, I want tubes etc.
