HiFiGuy528
Deep inside I am hoping the new D100 is a serious headphones amp from BiG Blue. Does anyone know?
Mac isn't Apple, they're not going to release something in 6 months to obsolete their most recent productD200 in the near future with pretty blue meters and dual headphone outputs?![]()
D100 can be used with any McIntosh preamp from model C20 through C1000. It has both balanced and unbalanced fixed outputs which can be connected to any high level preamp input such as AUX, Tuner, Tape and so on.
The way to judge sound quality is to connect D100 to one input and compare the sound of this to your other digital solutions such as the digital inputs of your C50. C50 will allow volume offset and matching of your sources that will when balanced in level provide an accurate comparison. If the volumes are not exactly balanced the louder source will always sound the 'best'.
As far as USB inputs unless you have a PC running a high quality music program that will bypass the computer's internal sound processing, you will not know how good USB audio can sound.
C50 or D100 both sound superb when they are used in asynchronous, bit perfect mode. C50/C48, D100 and MCD1100 all correct the digital data stream using the software driven McIntosh digital engine. This processing and correction of the digital data is performed before the signal is sent to the DAC for conversion to analog. Poorly made or recorded CDs and low data rate compressed music are all greatly improved by the McIntosh digital engine which results in superior performance as compared to others using the same DAC chips.
Thanks again,
Ron-C
Why yes it does and will work with 15 to 600 ohm cans. Should go live on the website tomorrow, Friday.
Thanks,
Ron-C
Oddly enough from the photos on the Mac website, unlike any other current Mac component or most other previous models, none of the nomenclature for the buttons and knobs are back lit.
I think McIntosh's biggest problem will be disgruntled customers who sprung for the MCD1100 when this is 1/4 the price and has the same DAC configuration.
Real happy that i sold my MCD500. I was only using it for the DAC since most of my listening is done via streaming. The D100 is the perfect solution for me. A great headphone amp, top line DAC and it's a McIntosh. The price is a bargain and McIntosh is not going to release a higher line version. If you want more features go for the c48 or c50 or the mx121 or mx151 for home theater.
D100 has fixed or variable outputs just like all McIntosh CD players so you can use it either way, fixed or variable. If you listen to headphones then you will can use the high performance headphone amp with the built in analog stereo volume control while at the same time the fixed output is connected to your preamp.
Much will be said about D100's performance and most will call it what it is, a bargain.
Thanks,
Ron-C
