hwirt
There's a video of the D100 on youtube and the "level" and "input" labels are not illuminated.
http://www.youtube.com/watch?v=qmNFYuYJfe0&feature
Everyone will get illuminated faceplates but yours.
Thanks,
Ron-C
Actually you will need to stop the music from your computer before you shut the preamp off. When you are using JRivers in ASIO mode, C50 is controlling the data rate packets from your computer. This is a two-way communication over USB.
If you shut the C50 off while in ASIO mode you have then broken the communication between the computer and the C50. Your computer will show a McIntosh ASIO error message when thsi happens. So when you turn the C50 back on and it USB handshakes with the computer, which it will, it will not initiate playback since when you shut C50 down while playing, you cut the ASIO communication.
At this point simply shut JRivers off and restart it on your computer and the C50 will lock right on without restarting C50 again.
USB two way, ASIO bit perfect communication, is not PCM one way where you can unplug and replug a cable. I do not have a D100 here right now but I would suspect it will operate the same way.
Thanks,
Ron-C
I will have to ask them. I have been using a prototype and it was lit just like the preamps. The problem is the bright lighting when these are shot. If it picks up to much of the golg teal it looks white.
Thanks,
Ron-C
Ask what? Everthing lights up except the word Headphone above the headphone jack just like every other preamp.
Thnaks,
Ron-C
Thnaks,
Ron-C
Nope. Three people who have now received theirs have confirmed that only the McIntosh logo lights up. The words INPUT and VOLUME do not light up. :thumbsdn:
Thanks,
Ron-C
