Dual 1019 in Action
Cadillac Kid
Addicted Member
Transfering a metal Audio-Scription 78 RPM disk of a 1940 radio broadcast. Sounds great on my Dual 1019.
That's awesome!
I'm in love with my 1019. It just makes everything sound so rich.
Nice setup!
The 1019 is a fine table. I just recently restored a few of them. I'm mostly playing 78's, but have stacked some 45's as well. I'm really enjoying mine as well.
I bought the Garage-A-Records kit for the lubrication. The only part I did not do was the motor bearing, I did not want to remove the housing until I do more research.
There's a few threads around here on taking the motor apart. You basically take a hammer and screwdriver and do some light tapping around the perimeter of the lower shell half and it comes right off. I held the motor lightly in a vise while doing this.
The motor came in two different versions. The one with little bolts and nuts and removable tabs will come apart without a sledgehammer.
I picked up a 1019 just for 78 duty a few months ago, while it doesn't have the clarity of a modern TT, I enjoy playing my 45s and 78s on period gear. For its age, it'd be hard to do much better!
Since it doesn't have the clarity of a MODERN turntable, then perhaps it is time to change the steel needle.
Way cool! I had no idea they made metal disks.
The 1019 is also one of the tts I have on my list of ones I want to own before I die.
Here is what the motor looks like. (Not my photo). I removed the bolts but the housing did not want to come off, so I abandoned the idea of lubricating the bearing.
Do you usually remove the motor?
Using a Shure cart and new styluses, not a steel needle. If you think a 1019 sounds as good as a modern belt drive, more power to you. For me, it doesn't come close to my MMF-5, but I still think it's a fine TT.
You need to remove those two bolts which are 180 degrees apart on the back of the motor, I believe. I usually remove the motor entirely from the turntable. It makes it much easier to work on. You only need to unsolder 4 wires.
Rick
OK. I did lossen the bolts but the back did not want to pull off. I think I will take it out, clamp it and add try to get it off. If I pull and it is still stuck, should I do the love taps with a screwdriver? Or is there some other way?
When I removed my motors, I just removed the switch with it so I didn't have to unsolder anything. Yep, just some light "love taps" is all it takes.
Mark and disconnect the wires.
Drop the motor.
Remove the pulley [loosen set screw and if no results, then pry up with two WIDE screwdrivers].
Remove both nutd/bolts/star washers.
Never place anything in those slots you arrowed.
Take one of those screwdrivers, and a good place to put it is against the edge of the lower motor shell.
Tap the screwdriver with a small hammer, going around the lower shell. Might be best to place motor in a vice first.
The bottom will come off, leaving the core with the upper shell.
Now you can soak the bearings with plain, additive-free engine oil.
Use nothing but, and soak a few times. There is a hidden wick around each bearing.
Your Dual is very old. You need to bite the bullet, and do the work.
Many of us find the Dual 1219 [similar unit] IDLER-DRIVE to be a giant-killer. Has the sound that no belt-drive can approach. And no rumble. So, some may say you are wrong, but we can all be thankful that you may think whatever you want in America.
