Dual 1229Q
I initially purchased it from the Bay (from a Canadian audiophile). Was packed well and arrived good. All auto functions worked flawlessly despite having no steuerpimpel
I also wondered myself, How in the world ...
But there was a multi mode issue:
When playing single play, everything worked fine and normal, but when the lever is switched from Single mode to Multi mode, the tonearm assembly would rise (as it would normally to compensate for VTA), but when you used the cue lever, it didn't even lift the tonearm up (even when it is just the first record being played from the stack). So at the end of play when the automatic cycle engages, it barely lifts it up - with the stylus almost touching the record as the arm swings back. In this case, any more than one record in the stack would be a catastrophe! I have already adjusted the cue control adjustment screw to its maximum at 8 mm (on Single mode).
In my DIY attempt to fix it (and attaching a "home remedy" steuerpimpel), I made matters worse. Upon putting it back together, I've noticed that something was impeding the arm. I noticed it especially when I observed the cantilever wiggled as if being dragged during play while the headshell remained stationary.
This is where Bill "Bohhey" Neumann came in. I sent it to him and he professionaly restored it to MINT condition. Bill said, the tonearm was binding because of the single/multi switch. The rubber collar was broken (typical) and the tonearm couldn't seat properly, so the plate underneath was binding on the height adjusting collar. Replaced with new collar, and all is well again. He also cleaned out the old grease off the mechanism, relubed it, installed a new steuerpimpel, and reversed the polarity of the strobe lamp to avoid flickering. He even fixed and tightened the wooden base where the dustcover hinges to stay up, and provided me with a new dustcover. Overall, an exemplary job from Bill that goes beyond the call of duty!
But it was my fault for not sending in the multiplay spindle with it for final testing, so some more refine adjustments were needed to be done because now, the records won't drop: 78s or LPs.
When I inserted the stacker spindle, I push it down through that notch then twist it clockwise to lock it down (Lock Down Mode). But at lock down mode, the upper part of the spindle (3 smaller prongs) doesn't retract all the way in, so that the stack won't go past through that. It should retract all the way in for it to come through, and rest on the lower part of the spindle which are the 3 larger prongs that support the stack.
It seems that there was a millimeter gap at lock down mode for the spindle to go down some more until it's at a dead stop. Because if I pressed it down to eliminate this gap, the upper part of the spindle (3 smaller prongs) retracts all the way in, and everything works normally.
This is where "NoTransistors" came in to help me resolve the problem (virtually) ...
"Not difficult.
Look at the end of the arrowed lever that is nearest the drop-spindle.
Believe it or not, the thing that looks like a bolt head is what you must rotate [a wee bit at a time] to adjust the amount of travel of the spindle prongs.
What? you may be thinking. On that rotatable nut, is a pin which is moulded in such a fashion, that by rotating the 'nut', you move the pin up or down. One full revolution of this 'nut' covers the entire range of the adjustment."
One last refinement was done when I decided to replace the old idler wheel because I could hear a faint thud every now and then. I sent the old idler wheel to Terry and he replaced it with a brand new rubber.
http://www.terrysrubberrollers.com/
Result? It is now even more silent than it was (just like a 701 Direct Drive now). I am now a very happy and satisfied owner of this Dual 1229Q, and this is my story. :thmbsp:
BTW, she's sporting a Shure M91ED. Lovin' the sound of the 70's!
