Empire 2200 E/III Cartridge
Mwdan
I've searched quite a bit and can't find any useful info about this cartridge. I take it that the E/III is the stylus type? Is it considered to be a fair or decent cart? How does it compare to the Empire 2000?
Same. Empire marked their carts in the "blob" series with countless designations. It was kind of a marketing strategy. Basically there are the silver ones and the gold ones. Resistance/inductance can differ from model to model and even the same model. Some are around the 530 ohm range and some are around the 1100 ohm range.
Thanks Brent.
Well, the 2000 E/III isn't really the same as the 2000. The bodies are the same, as far as we know, but the E/III stylus (clear - no color) is a .2 X.7 mil elliptical, more compliant and has better specs. The 2000 stylus (transparent smoke color) is a ,7 mil. spherical with not-quite-as-good specs.
All of the 2000E series have decent specs, however.
EDIT: DANG! I misread the thread title and thought it said 2000 E/III. Oh well. darned eyesight, anyway!
Doug
A quick hint to aid future searches: Try searching with and without spaces in a cartridge's name. I know that's a pain, but it can make the difference. In this case, "2200E/III" would give you the info you wanted.
