EQ to pre amp in/ out
troutfisher
Well-Known Member
I'm going to try hooking my pioneer 9500 EQ up to a Sansui 8080 using the pre in and out and was hoping someone could post a drawing of how it should be hooked up.
Hi TF!
I found this diagram in my stash of old images. Maybe this will help with the others advice with pre in-out connections.
Rome
You should run the EQ through the Tape loop, not the pre out/main in. The EQ will likely introduce alot of noise through the pre out.
The upshot of all this is that it depends. There is no answer that works all the time.
Try it and see if you like the results. You are highly unlikely to damage anything.
