EQ hook up
troutfisher
Well-Known Member
Can someone help me?
I'm trying to hook up a pioneer EQ and when I switch from r2t to cassette it seem like the EQ is not working am I hooking something up wrong?/
Thanks
this is what I have and how it is hooked up
Yamaha cr 600-pioneer 707 r2r-teac v 3000 cassette-pioneer sg 9500eq
tape a cr600 rec out to input on eq
tape a cr600 pb to output on eq
tape b cr600 rec out to line in on cassette
tape b cr 600 pb to output on cassette
eq tape rec to r2r input
eq tape play to r2r output
I do not see how both the cassette and the r2r can go to the eq ???
It all looks to be connected properly with about 3 different possibilities, but let's go with what you have already.
Leaving everything connected the way you have described:
To listen to the cassette on tape B > Tape monitor switch to TAPE B.
To listen to the cassette through the EQ > Tape monitor switch to TAPE A, RECORD SELECTOR switch (or tape dubbing switch) to TAPE B ( or tape B > A ), equalizer switch to EQ IN.
To listen to the reel-to-reel through the EQ, Tape monitor switch to TAPE A > EQ switch to TAPE.
i got it to work not sure what I did but it works.
I switched the r2r and the cassette around on the back of the cr 600 and started throwing some switches and every things works.
Thanks
