kwingylee
Well-Known Member
Today I was able to sufficiently modify my AMT-3 cabinets to accommodate the pair of Dayton RS270P-8A 10 inch woofers. I mounted and wired them to the stock crossovers. I also added a Lpad on the Alpha 6A midrange. I did not have the great Heils tonight but used my JBL 2404H and Electrovoice ST350A for the highs (would not recommend either one for this application without EQ). I am including a picture with the ST350A here.There is a 10 ohm resistor in series with the tweeter to pad in down... its barely tolerable.
To get a sense of the subjective quality of the AMT 3 bass with the new woofers. I drove them with a New American Sound/Bedini 100/100 Mark 2 amplifier (background to the right). It definitely performed much better than the Goldwood GW10PC-8 and Radioshack 10 inchers that I had in these cabinets before. Bass quality is very good and clean. The Alpha 6A need to be padded 1/2 way down on the Dayton 8 ohm LPAD to get the right tonal balance. Very promising sound so far. Next, I will add more bracing to the back of the AMT3 cabinets, sealed around the woofers and MAYBE line the walls with insulation. Of course connect the Heil tweeters.
The only drawback so far is that volume and efficiency wise, the AMT-3 cannot compare to the UREI 813As and the Altec A7s as seen in the backgorund. This is to be expected as the Altec/UREIs are around 100dB 1W efficient, and the AMT 3s are no where near the final product. I still need to seal the woofers and the port.
Has anyone ever measured the max SPL of the AMT-3s just to make sure my expectations are realistic?
