Put a meter on those controls and see what kind of resistance you get.
Yes the horns are definitely working, though muted and quieter than my other speaker. Thanks for the ideas.Just out of curiosity, have you placed your ear next to the horns to make sure they are functioning at all? If they are, these guys have you on the right track - either/or the caps drifting/controls/maybe even corroded wire connections (happens all too often on old speakers! Every connection, even if it looks good, should be suspect.)
GeeDeeEmm
This makes sense, I will check out the threads for more info..It's possible the B&P control is sufficiently corroded internally to be attenuating the incoming signal. If the control is only passing a signal at certain points along its path of travel, I would sort that out first before attacking the crossovers. I have not taken an EV control apart so cannot describe the process. They are similar to the controls used in vintage AR speakers. There are numerous threads here in AK devoted to refurbishing AR controls. I hope this points you in the right direction.
Curious what everyone thinks. If I can get the speaker cranking like it should, would it make sense to change the X336 to the dual X325/X36 crossover combo? Would it make any difference?
I've had a few including a '69. My first car was a '68. I currently have a '64 convert, and a '70 Judge. But no one here cares, let's talk vintage speakers! Lol.Which GTOs do you like/own, Jon?
My favorite was the 1969 model. Had three of them, the last one was a frame-off, ground up restoration except for the paint.
GeeDeeEmm
Sorry for the slow reply...Those look like modern film caps, so they appear to have already been replaced in that crossover. Probably why there is no potting tar in there too. Looks like the spec sheet on the 336 says they are potted in 'thermoplastic asphalt' which means warming it will make it soft again.
In any case you can see what a simple soldering job it is once you identify the cap values and get replacements.
Just saying. But Amrad's history page says that in 1966, they formed the "Precision Capacitor Division which specializes in close tolerance, highly sophisticated, film dielectric capacitors." I did not really know when film caps were first made but they go back quite a ways.would it make sense to change the X336 to the dual X325/X36 crossover combo? Would it make any difference?
