Get well soon! Best wishes!ON HIATUS IN HOSPITAL
My apologies, didn't realize. Have started a new thread here.This thread is Mark's and is for those who need their clutch repaired. Best thing to do is start your own thread and someone will assist.
That pulley rubber seems to be heavily worn out. If the clutch moves freely try to clean its touching surfaces with non-invasive chemicals, like soapy water and que-tips. Check the tire on the clutch if it is cracked, hard etc. If it is then you would need to source out replacement. There is great guy van-hurban on e-bay that stocks replacements for most of the vintage gear, try there. You should also give attention to the pulley rubber. In case you cannot find its replacement try to increase its diameter by applying a shrink tube over the existing rubber.New to this forum and I appreciate that the initiator of this great thread is unavailable. However, wondering if anyone else can offer advice. I'm trying to restore a CT-F9191 I've owned since 1976. Like others, it will not high-speed wind or rewind. I've removed and diss-assembled the clutch and it does not have a cracked spindle and rotates freely on its shaft when turned manually. Selecting fast wind or rewind does activate the lever and moves the clutch to the motor shaft (which does spin) and to the appropriate cassette drive spindle but the clutch itself does not rotate and hence neither do the cassette drive pulleys. I assume there's insufficient grip between the motor shaft and the clutch and whilst there are groves on the clutch and rubber on the motor drive shaft, I suspect they are too worn but can't be sure as I've never seen unused ones. I've attached photos of each and would appreciate any comments or ideas.
Many thanks
View attachment 3027826View attachment 3027809
For the pulleyNew to this forum and I appreciate that the initiator of this great thread is unavailable. However, wondering if anyone else can offer advice. I'm trying to restore a CT-F9191 I've owned since 1976. Like others, it will not high-speed wind or rewind. I've removed and diss-assembled the clutch and it does not have a cracked spindle and rotates freely on its shaft when turned manually. Selecting fast wind or rewind does activate the lever and moves the clutch to the motor shaft (which does spin) and to the appropriate cassette drive spindle but the clutch itself does not rotate and hence neither do the cassette drive pulleys. I assume there's insufficient grip between the motor shaft and the clutch and whilst there are groves on the clutch and rubber on the motor drive shaft, I suspect they are too worn but can't be sure as I've never seen unused ones. I've attached photos of each and would appreciate any comments or ideas.
Many thanks
