This could be huge. I have a number of high-end Pioneer cassette decks that I've had in dry dock for years. I would LOVE to get these back up and running with new parts!A few more plastic parts are printed for these decks.
The playback pulley for the tape counter is another that cracks.
I have a print for that. There's a spring that is held in using the force fit of this pulley. I the fit isn't tight enough on the spindle, the assembly will come apart, and pieces will fly. I was able to find all the parts
Also the capstan lateral take-up spacer was broken (Below image) in the past and someone had glued it in.
I have a print for that as well. They are not even shown on the exploded view.
Any updates on how the process is going, and how the new printed parts are holding up? Tackled printing 9191 parts yet?!? Keeping my fingers crossed for all of us!!! Send our best to Mark…We are able to print everything that’s been needed so far, for this F1000. There are other plastic bits that could be potential issues.
I’m confident we can reproduce any damaged plastic parts.
Welcome to AK!hi all. apologies if this isn't the pace for this question, I'm new to the whole forum thing. Can any members who know a bit about these decks tell me if the CT-F6161 also suffers from this idler clutch issue? I found one i'd love to buy but not if there's a high risk of common failure. thanks for any help from the experts
Welcome to AK, glad we could help!Dear all, thank you for your postings on this matter. Was kindly helped by Zebulon on the clutch work. Although the clutches were repaired, the idlers turned aleatory. What did the fix for me was then changing ALL belts, on idler, counter, driver and especially the motor gummi. I read somewhere they get dull from rotating against a clutch that didn't work. So that did the trick. Also make sure the new motor gummi is well engaged on the clutch for perfect contact. Thanks again, a pleasure to repair two 9090 units I have known and played since I was born. greetings
Are you sharing the STL files? Or selling the parts? I have a bad clutch on my 9191 and need the partsWe are able to print everything that’s been needed so far, for this F1000. There are other plastic bits that could be potential issues.
