OK Dave: Good jack hack point about the voltages!! I assumed (bad word) the originial caps were discharged. Capacitors store electricity - that's their function - so if you power up your amplifier, those can capacitors can have up to 400 volts stored in them. If the amp is on the bench and has not been powered in a while, they are safe, BUT just to be sure, take a screwdriver with
an insulated handle and touch each of those contacts at the base of the can caps to ground. Or - use an alligator clip jumper wire, connect one clip to the chassis and the other to the screwdriver and touch each terminal. To see the danger, power it up, then unplug it, and touch each terminal to ground -- you will see a big spark as it grounds out. Key though, is to work with a discharged chassis --nowhere near being powered up. JHack is right on --
those voltages can kill you! Be safe and sure.
Now--Do you have a schematic for the amp?
I did recap the filters in my 460A, and I thought of you by
taking some picures. But I cannot figure out how to put arrows on the photo or how to mark the photo somehow to point out what I talk about. So - you'll just have to read the values on the replacement caps as we go. Another thought, my amp is not going to the Pebble Beach concours d'elegance competition, so it is not pretty or perfect. Perfect is the enemy of good enough. I am a functional fella. Also - remember this - resistors in series add, and capacitors in parallel add. Eg: two 47mfd 450v caps wired in parallel equal 94mfd @ 450vdc = close enough to 100mfd used in the 460A. Another Eg: a 47mfd 450vdc cap wired in parallel with a 10mfd @ 450vdc = 57 mfd @ 450vdc - close enough to the 60 mfd used in the 460A. I have these caps in my parts bin -- when you order, you'll get one cap say at 100mfd, so you don't have to wire two of them in parallel. But if you know the rule, it may come in handy in the future. So my replacement caps are two caps wired in parallel to give me the necessary values. Notice that the can with the cardboard cover has the case or shell of the cap NOT grounded to the chassis. The upper two caps do ground to the chassis. The cardboard covered cap is a 100mfd @250vdc and the negative side is connected to the red/yellow wire coming out of the transformer ( high voltage secondary) - the positive side is connected to the red wire that is the other end of the secondary high voltage winding.
The first picture shows that I have wired in the two black colored 47mfd caps with the resistor across both positive ends. Those two are for the 40mfd in the top left cap that ground to the chassis. By the way, you must have a newer version of the amp because your wiring is a little different than mine. My dropping resistor is 2200 ohms and yours is 3300 ohms. Your layout of the green 220 ohm resistors is different than mine and your rectifier diodes are different also. You said you didn't know a rectifier from a capacitor -- now you will! The rectifier diodes in yours are the two little cylindrical shiny metal doodads that are connected to the red wire coming out of the transformer. The upper one goes directly to the chassis ground, and the lower one goes to the only positive terminal on the cardboard covered can = 100mfd @250vdc. The function of the diodes is to change the alternating current from the wall and the transformer to direct current for the amp to use -- they only allow current to flow in one direction. The capacitors we are changing filter that direct current to make it more pure and direct (straight line) by absorbing and grounding whatever alternating current there still is riding with the dc. By the way, I said the amp is filtered well -- by that I meant we have a lot of capacitors filtering the direct current along the path it takes. An old tube radio uses two filters generally, we have seven!
The better you filter and purify the dc, the better and more pure will be your sound (good for an amp!!). Back to the pictures: pix 1 shows I have clipped the terminals flush with the chassis on the two upper cans. This gives me more space to mount the replacements. The two light blue caps to the right are 47mfd @ 160vdc replacements for the 100mfd 100vdc cap that is in the second shiny metal can. The ground for these two has not been made to the chassis yet -- it is just waiting to see what space will work out for it.
The two black 47mfd@450vdc caps in the center have a diode riding above them. Notice that the negative (metal ends) for those two does NOT go to the chassis. There is an orange wire from the ground that goes to the green little 220ohm resistor over to the left and up. We talk more about that later. We've covered three replacement caps. There are two left and they are one black one--47mfd@450vdc with a light blue one wired in parallel -- 10mfd @ 450vdc. The two of them in parallel equal 57mfd @ 450vdc = good enough for the two 60mfd 450vdc needed. So they are wired in across the 220 ohm resistors (+ side) an the negative side (metal end) going to chassis ground.
The next pix shows I have laid the two little blue caps down and soldered their negative end wires to the chassis.
The next pix shows a little piece of styropfoam I put down on top of the old can bases just to provide a firm base for the last cap.
I like that stuff "GOOP" - I let it age some so it isn't so runny, and then use an ice cream stick to put it on the chassis to hold the styrofoam in place. The next pix shows the 100mfd @ 350vdc replacement for the 100mfd-250vdc -- I put some GOOP on top of the styrofoam and press the cap down onto it just to prevent any movement. Notice the positive end of that 100mfd goes to
negative of the 100mfd cap that did NOT ground the the chassis --and also to the red/yellow wire. (The negative goes to chassis ground at the same point where the two little blue ones are grounded.) You might notice the red/yel wire just hanging out there - I haven't hooked it up to the 100mfds yet. The very last pix shows the finished job. The red/yel wire is soldered to the negative end of the 100mfd coming from the diode. Also soldered there is the positive of the 100mfd 350vdc and I've replaced the orange wire you saw before with a new
black wire running over to the top left and the 220 ohm resistors. I also put a big piece of shrink wrap between the diode and the 2 47mfd-450vdc caps just for more isolation. That's it. Works like a champ and the sound is terrific with plenty of punch.
Take it slowly and methodically and take notes, as we said. Your pictures will help trace wires if you get in a bind. If you need the schematic let me know. I have a schematic that is not exact but is close enough.........good luck! I live in the Shenandoah Valley - right against the
Appalachians - little settlement called St. Luke 5 miles west of Woodstock. Good show on UVa!!
best, steve
ps: you really can do this and be sure you are disconnected from the power! When you do the filters, we can talk about the coupling and bypass caps on the right side of the chassis --- no big thing.
