keithpgdrb
bump because I'd like to do some of this today. Power tubes out, what about the rest for the slow bring up?
To replicate a variac, you start with a low wattage bulb and move to a higher wattage one. But if any bulb come on with full brightness, you have a short and need to troubleshoot.
You should be Ok. The voltage isn't that high. Tube gear likes a load at the speaker outputs, but if it's not there for a while, it won't break, especially at low voltage. One of the reasons there are so many people willing to take on working on tube gear is that the gear is very forgiving and typically only burns out one thing or sometimes nothing.
In some solid state circuits, if something goes, there are often cascading failures in the surrounding circuitry.
At the reduced voltage I'm assuming the glowing he's seeing is filaments.
This is how it should work. The stereo beacon light is driven by the 6GK5 tube behind it and a relay. There are two different FM stereo positions. Choose the other one and that light will stay on.
Regardless of whatever the behavior is, that circuit ain't broken.
