With all the data analyzed from the measurements taken, the improvements to be implemented to the X-1000 will be grouped into two categories: Basic, and Advanced.
The Basic Improvements are slam dunk improvements that will work to greatly improve flexibility and sonic presentation based on today's audio needs, while the Advanced improvements will take both of these qualities to the limits of what is possible within the basic framework and of the X-1000's design. In the process, both the control and power amplifier sections will undergo a thorough upgrading.
Within the control section, this unit has all the issues I have mentioned before regarding the tape recording and playback facilities provided:
1. The signal provided at the Recording Output jacks is reversed in phase from the source signal provided to the unit. Therefore, any recordings made from these jacks will be recorded in reverse phase as well. While the existing Tape Monitor inputs ALSO reverse phase (compared to all other inputs) to correct for this within this unit (if that input is used for playback), it still leaves a non-standard signal recorded on the recording device, making accurate playback only possible when played back through this unit.
2. The signal provided at the Recording Output jacks is isolated from the individual input sources, but not from the signal chain within the X-1000. Therefore, any device connected to these jacks will affect the sonic presentation presented by any input source selected.
3. The sensitivity level of the Tape Monitor input is much less than that of the other inputs. While this input is currently phase compatible with the current Recording Output signal, the reduced sensitivity at the very least makes this input less desirable for general playback, and reduces its flexibility as a usable input setting for other devices.
4. The Tape Monitor and Aux 1 input jacks include a bleeder circuit between them, originally to allow normal playback through the Aux 1 setting, while monitoring during recording was to be done with the Tape Monitor switch. This effectively uses two otherwise separate input settings to accommodate only one input signal. Not only does this reintroduce the reverse phase issue again when listening to playback through the Aux 1 setting, but also hinders input flexibility versus today's multitude of source capabilities.
If you don't use any of the tape facility jacks, then these issues may be of little importance to you. However, in today's audio world, while some still use these jacks for recording purposes, such jacks are more typically used to provide a loop capability to switch in or out external signal processing devices, equalizers, or other switching units. As is however, with the myriad of issues surrounding how these jacks were integrated into the design of the X-1000, their value is greatly diminished towards any of their possible uses. The modifications to be installed not only correct all of these issues, but also provide a very low output impedance at the Recording Output jacks -- independent from the signal chain through the X-1000 -- that allows for even modern SS gear to be connected to these jacks with no degradation of the signal whatsoever -- either as presented to the external device, or as an effect on the signal passing through the X-1000 when an external device is connected.
These modifications then will greatly enhance the X-1000's ability to interact with today's audio environment -- and come at the expense of losing the center channel (i.e mono) record output facility (who uses that?), and the active phase reversal capability for Channel B signals. Since both of these features are completely lost on today's audio needs, I am rather certain that they will hardly be missed. Their loss then can be parlayed into a nice gain in overall flexibility and operating capability.
The control section also includes two filter circuits: A permanent low frequency filter (independent of the switchable one), and a switchable high frequency filter. But even when the high frequency filter is turned off, its design still has the signal passing through the majority of the components that make up this filter. The HF filter components are located on a PEC which invites tolerance issues, while passing the signal through the filter components in general brings in frequency phase issues even if response is not limited in the off position. The result is that detail and dynamics suffer from these circuits. Ultimately, for the vast majority of today's sources, these filters are no longer required, and limit performance. Removing them completely solves these issues -- issues which in the unlikely event of still needing to be addressed, could be much better served with an external unit designed expressly for this purpose, now connected via the revised/corrected tape connection jacks as discussed above.
These modifications then would make up the changes made under the Basic Improvements list, making the unit much more flexible, and sonically transparent in the process.
Under the Advanced Improvements, three issues will be addressed.
One, as already mentioned, this unit as a whole reverses the phase of a signal passing through it. This gets rather tiring to analyze considering the phase issues associated with the tape jacks as previously discussed, but suffice to say, that it does invert the phase of any signal applied to any of the selector switch inputs. Correcting it is easy in concept: Either one stage of amplification has to be added to the signal chain, or one has to be removed. Either approach will accomplish this task. But since space and tube count are already limited, and invariably a shorter signal path is always better than a longer one, then removing one stage is the way to go. However, if a stage is to be removed, then another will have to pick up the slack if the overall sensitivity of the unit is to be maintained.
Currently, tests are being run to determine the viability of eliminating the first line amp stage, and allowing the second line amp stage to act in place of both. Both were originally used to facilitate the LF filter in one stage, and the HF filter in the other. But since these filters are going to be removed, then that opens the door to eliminating the first stage altogether, which if the other stage can be made to properly compensate for the loss of the first one, then allows for correcting the phase reversal issue in the process.
Secondly, if possible, that frees up one tube section in each channel, that can now be used to properly facilitate Preamp Output/Power Amp Input jacks via the old Reverb In/Out jacks -- similar to what I did in my Fisher 400 Modification thread. Not only then would the phase reversal issue be corrected, but now the unit would have limitless possibilities in interacting with other power amplifiers or preamplifiers -- or crossovers for bi or tri amping even -- that otherwise would just not be possible with the stock unit.
Finally, this unit also features a powered center channel speaker output, which made for great feature advertising back in the day, but makes for measurement nightmares and incompatibility with many external speaker switching units -- all because the Common output terminal in each channel is not at ground level in the X-1000. Therefore, any external switching device that depends on the Common output terminal of each channel being electrically identical (because the Common input terminals of the switching device are connected that way) causes major problems when used with the X-1000, as they effectively place a short across what are otherwise hot output terminals. Therefore, the third item under the Advanced Improvements would be to modify the output circuitry of the power amplifiers, so that the Common output terminals will in fact represent ground in the traditional manner.
Doing this will requiring checking the feedback networks for proper operation with the revised output configuration -- not only to maintain the original feedback level (19 db), but also to ensure that stability and frequency response are maintained. Since the last two items have already been identified as a problem in this particular unit, this will be the opportunity then to address them.
About the only feature that cannot be readily addressed in this unit is including a tone control bypass feature. Because the tone controls in this unit are of an active design, they use a stage of amplification, and invert signal phase in the process. To bypass them then means having yet another stage available to switch in place of the tone stage to maintain phase when bypassed, but with an otherwise flat response. When judged against all the other improvements made possible with reallocating the the various stages freed up for their new duty, this fell to the bottom of the list -- particularly so, because as an active tone control design, the flat setting can be made very accurately, largely eliminating the need for a bypass switch to begin with.
So, the plan is coming together. The modifications for the Basic Improvements are all determined and ready to be executed. For the Advanced Improvements, the modifications themselves are established, while tests continue to see if one line stage can be properly eliminated -- which will then determine if the phase reversal issue and Preamp Output/Power Amp Input jacks can be facilitated. There is no doubt that one line stage can be eliminated. The trick is, can it be eliminated, while still maintaining a reasonably similar overall sensitivity and proper frequency response for the unit as well. I hope to have this final testing of the unit finished up by early next week. Then, after some final listening sessions for the (basically) stock unit, the real work will begin.
Stay tuned......
Dave
